They've said that? I haven't seen it, but I'm taking it to mean yes the same philosophy but without last year's compromise. More efficiency means they can have their downforce cake and also eat some more top speed. But let's see. Ferrari have probably come in the opposite direction.
Could give them more flexibility to go with a lower downforce setup, true.kimetic wrote: ↑14 Feb 2020, 16:07They've said that? I haven't seen it, but I'm taking it to mean yes the same philosophy but without last year's compromise. More efficiency means they can have their downforce cake and also eat some more top speed. But let's see. Ferrari have probably come in the opposite direction.
The last upgraded PU they introduced, was back in Belgium in September. That PU must have gone in to production by August. Since then, they would have 5 months to bring the upgraded PU for their first race of 2020. Even if by conservative estimates if they have added 25 HP, it would still be good enough to make them "a lot faster" on the straights than last year with the same level of drag. "IF" they would have found more than that, it would be anybody's guess as to how fast that would be on straight.Seanspeed wrote: ↑14 Feb 2020, 16:04Faster maybe, I just doubt 'a lot faster' as claimed. At these speeds and downforce/drag levels, you need a fair bit more power to gain meaningful boosts in straight line speeds. So I wouldn't expect some big increase here when they say they have similar drag levels as last year.
Well I wouldn't think 25hp would make a huge difference on top of 1000hp in a high downforce F1 car at 160mph+, but ok. I suppose what we consider 'a lot' is subjective.GPR-A wrote: ↑14 Feb 2020, 16:12The last upgraded PU they introduced, was back in Belgium in September. That PU must have gone in to production by August. Since then, they would have 5 months to bring the upgraded PU for their first race of 2020. Even if by conservative estimates if they have added 25 HP, it would still be good enough to make them "a lot faster" on the straights than last year with the same level of drag. "IF" they would have found more than that, it would be anybody's guess as to how fast that would be on straight.Seanspeed wrote: ↑14 Feb 2020, 16:04Faster maybe, I just doubt 'a lot faster' as claimed. At these speeds and downforce/drag levels, you need a fair bit more power to gain meaningful boosts in straight line speeds. So I wouldn't expect some big increase here when they say they have similar drag levels as last year.
Is there any image covering this adventurous rear suspension?PlatinumZealot wrote: ↑14 Feb 2020, 16:38Very adventurous rear suspension!
I can see how it unlocks the aero performance envelope.
James Allison: “At the rear of the car we have gone for an adventurous suspension layout in order to free up aerodynamic development opportunity."PlatinumZealot wrote: ↑14 Feb 2020, 16:38Very adventurous rear suspension!
Although if one is able to make more drag for a given downforce level, one can trim a bit of downforce and drag and still be decently quick. Obviously, it's circuit dependent as to where the balance is between downforce and top speed. If you can have more downforce for the same drag at somewhere like Monza then you're in good shape.Seanspeed wrote: ↑14 Feb 2020, 16:04Faster maybe, I just doubt 'a lot faster' as claimed. At these speeds and downforce/drag levels, you need a fair bit more power to gain meaningful boosts in straight line speeds. So I wouldn't expect some big increase here when they say they have similar drag levels as last year.
One of the drivers is quite good at looking after the tyres too...maybe this year with even more downforce both will be as accomplished.Giblet wrote: ↑14 Feb 2020, 18:29Mercedes was the first to add large data logging camera pods during testing, and have largely understood the tires better than everyone else, almost every single year.
They are using the same tires as last year, they already know them intimately, and where they were lacking.
