McLaren MCL35
Ground Effect
Ground Effect
Re: McLaren MCL35
_cerber1 wrote:
15 Feb 2020, 18:43
https://twitter.com/ivanlda/status/1228669501912309760
Hello Daniel. Thank you very much for your words. The numbers tell us that much better than the MCL34, so hopeful that it is a good base with which to be able to go on giving enough war.
Ivan also this on Twitter: Many thanks! On paper, it's quite a bit faster than the MCL34.
hollus
Re: McLaren MCL35
The usual gentle reminder:
Thunder wrote:
10 Feb 2020, 11:38
This is the McLaren MCL35 offical car thread.
Please discuss ONLY technical items of this car, and refrain from speculation.
Livery Talk also belongs in the Team Thread. viewtopic.php?f=15&t=28681
michl420
michl420
Re: McLaren MCL35
Crash test Regulation for the nose are different since 2014, the solid part of the nose must begin 5cm behind the tip. But a glue on is of Course possible. The whole car is costructed with glue. :wink:
Re: McLaren MCL35
_cerber1
268
Re: McLaren MCL35
The sound of the engine is amazing. =D>
BosF1
BosF1
Re: McLaren MCL35
The engines all across the field sound so much better in comparison to how they sounded when the hybrid era started!
the EDGE
the EDGE
68
Re: McLaren MCL35
A nice summary by Matt Somersfield,
Lucky
Lucky
157
Re: McLaren MCL35
OzanA
OzanA
Re: McLaren MCL35
Bargeboard looks so complex in daylight
Re: McLaren MCL35
And for those saying the car is 'fat' at the rear...take a good look at that video and the light shining through the car from the other side as it exits the garage:
You can see the undercut much better in person or in the video. I'm not saying it's the slimmest car on the grid but fat it certainly isn't.
Ground Effect
Ground Effect
Re: McLaren MCL35
_cerber1 wrote:
16 Feb 2020, 10:47
@_cerber1, do you know if @TheBestF1.es are reliable, regarding sources or info? They’re the second outlet reporting the introduction of the S-duct on the MCL35 for winter testing. Perhaps they’re just lifting that from Piola’s article on Motorsport.com?
Re: McLaren MCL35
View from the top...
the EDGE
the EDGE
68
Re: McLaren MCL35
PhillipM wrote:
16 Feb 2020, 12:07
https://i.imgur.com/ZgnwkRJ.png
I think when people mistakingly think the car is ‘fat’ it is because of the width of the engine cover outlet, which lets be honest is wide (and ‘odd’ looking In release renders), which is even more exaggerated because of just how small the side pods really are
Does this clip give us the best look at the new bargeboard area so far, are are there higher res images available?
mwillems
45
Re: McLaren MCL35
PhillipM wrote:
16 Feb 2020, 12:07
About half second on from that shot you get a real view of how extreme that undercut is. Will be interesting to see what that equates to on the track.
-Bandit
charliesmithhd
67
Re: McLaren MCL35
Turning vanes under front suspension look new
