These guys have so much endurance...unbelievable! Even a robot's battery would have ended by now...
Heat must be come from somewhere and they will use it only for gaining enough heat on the tyres, may be just for one straith. That not cause anything bad but cold tyre can cause many thingHolm86 wrote: ↑20 Feb 2020, 13:55Im pretty sure it's not to get heat into the tires, because if you use it for added scrub, only the surface of the tire will heat up, causing graining. Its the same when a car doesn't have enough downforce and slides too much, it also causes graining.
It must be for less tire resistance on straights
Although I don’t think heat is the main issue it HAS to reduce/increase scrubbing if it’s changing the toe of the wheels. Which HAS to change how much temps the tyre create.Holm86 wrote: ↑20 Feb 2020, 13:55Im pretty sure it's not to get heat into the tires, because if you use it for added scrub, only the surface of the tire will heat up, causing graining. Its the same when a car doesn't have enough downforce and slides too much, it also causes graining.
It could also be a way of removing heat too. It depends on which side of the coin you’re looking at. I’m not certain tyre heat is the main reason for it though it could be loads of things. It could be to reduce tyre wear in general, resistance, etc.etusch wrote: ↑20 Feb 2020, 13:57Heat must be come from somewhere and they will use it only for gaining enough heat on the tyres, may be just for one straith. That not cause anything bad but cold tyre can cause many thingHolm86 wrote: ↑20 Feb 2020, 13:55Im pretty sure it's not to get heat into the tires, because if you use it for added scrub, only the surface of the tire will heat up, causing graining. Its the same when a car doesn't have enough downforce and slides too much, it also causes graining.
That is true, but I still think its reducing scrub, for lower resistance, and as some say maybe even work in conjunction with POU to change ride height. Maybe thats why their POU is that extremeRestomaniac wrote: ↑20 Feb 2020, 14:01Although I don’t think heat is the main issue it HAS to reduce/increase scrubbing if it’s changing the toe of the wheels. Which HAS to change how much temps the tyre create.Holm86 wrote: ↑20 Feb 2020, 13:55Im pretty sure it's not to get heat into the tires, because if you use it for added scrub, only the surface of the tire will heat up, causing graining. Its the same when a car doesn't have enough downforce and slides too much, it also causes graining.
so the toe angle in Mercedes' setup sheet will be: "it varies"34.1 Every team must provide the FIA technical delegate with a suspension set-up sheet for both of their cars before each of them leaves the pit lane for the first time during qualifying practice session.
They won't be terribly concerned with graining they are just priming for a qualy lap.Holm86 wrote: ↑20 Feb 2020, 13:55Im pretty sure it's not to get heat into the tires, because if you use it for added scrub, only the surface of the tire will heat up, causing graining. Its the same when a car doesn't have enough downforce and slides too much, it also causes graining.
So the rules say fixed steering wheel but don't mention what fixed means. I think the spirit of the rules is the wheel should be only rotated and translation shouldn't be in its degrees of freedom.10.2 Suspension geometry :
10.2.1 With the steering wheel fixed, the position of each wheel centre and the orientation of its
rotation axis must be completely and uniquely defined by a function of its principally
vertical suspension travel, save only for the effects of reasonable compliance which does
not intentionally provide further degrees of freedom.
Nothing, and since the POU are outlawed next year, there's not a lot of point to running the system next year.mertol wrote: ↑20 Feb 2020, 14:38So the rules say fixed steering wheel but don't mention what fixed means. I think the spirit of the rules is the wheel should be only rotated and translation shouldn't be in its degrees of freedom.
Furthermore if they deem this legal what's stopping the teams from implementing a system with more than 2 options? They could shift the wheel like a manual gearbox and have a different steering profile for each corner.
One is "auto" the other isn't. Maybe someone should explain that to Cyril?
