That would indeed be theoritically possible, as are all passive system really, but difficult to have it work at the appropiate time.hamilton#1 wrote: ↑20 Feb 2020, 15:50I'm definitely not an expert, but is it possible for it to be a passive system? The tires want to stay in a straight line, because it has less resistance. So when entering the straight, the toe becomes 0 degrees and the steering wheel is pushed back. When approaching the corner the steering column moves back to its original place because of the forces due to braking.
I sounds a bit farfetched and this would also mean that the steering column is moving al the time. Even mid corners and I think that would mean that the are not able to fully control it and therefore control their balance.
Please don't judge me on this idea. I'm just a Formula 1 fan trying to maybe add some thoughts.
The point is:geraldix wrote: ↑20 Feb 2020, 15:30I can't understand all this fuss about DAS legality...
It's pretty OBVIOUS Mercedes that has just spent a bunch of months, human resources and millions of dollars developing, building and testing a system that's completely ILLEGAL. Maybe for fun, maybe because they are just ignorant. After all, what do they know about building an F1 car?/s
Is it illegal because the steering isn't allowed to change the toe angle? Maybe, maybe not...
yeah, this is clearly longitudinal movement, the engineer in me is dying everytime i've read lateral...
For it to be passive, and pass in this forum, it'd have to somehow include Hg.turbof1 wrote: ↑20 Feb 2020, 15:54That would indeed be theoritically possible, as are all passive system really, but difficult to have it work at the appropiate time.hamilton#1 wrote: ↑20 Feb 2020, 15:50I'm definitely not an expert, but is it possible for it to be a passive system? The tires want to stay in a straight line, because it has less resistance. So when entering the straight, the toe becomes 0 degrees and the steering wheel is pushed back. When approaching the corner the steering column moves back to its original place because of the forces due to braking.
In reality I don't think it is feasible. They couldn't get a passive DRS working properly or make it worth it, and this sounds massively more complex to pull off.
I don't think so, I think that would count as a suspension setup change. Camber effectively changes as the car goes through corners, but only relative to the road, not the car.
It will end up at a FIA technical tribune though should it be declared illegal by a steward. Mercedes would no doubt appeal such a decision.jetho wrote: ↑20 Feb 2020, 15:58The point is:geraldix wrote: ↑20 Feb 2020, 15:30I can't understand all this fuss about DAS legality...
Is it illegal beacue it can be argued to be a moveable aerodynamic device? Maybe, maybe not...
Is it illegal because it will also effect the ride hight? Maybe maybe not...
There are a lot of arguments to be made for and againt ist. Just because Mercedes thinks it's legal and spent a lot of money on it doesn't mean it actually is.
Even Mercedes saying they have 'cleared' it with the FIA doesn't mean anything. What they have most likely done is asked the FIA during the summer wether their idea is legal and the FIA has given an opinion about it.
An idea and a final implementation are two very different things.
An opinion and a verdict are two very different things.
Also, afaik the FIA can give opinions, write the rules and technical derectives, but only the stewards at a race can declare the legality of something.
