What's that?Mark4211 wrote: ↑22 Feb 2020, 16:37They have started using other BBAL offset values apart from .5%.
Pictured: 56.8% BBAL
https://i.imgur.com/FSWtDSI.png
The point is, the toe angle is being changed as a result of steering input, which is perfectly legal and necessary for car to actually go around a corner. If the steering input required to operate DAS is breaking parc ferme, then any steering is breaking parc ferme and all cars are illegal. There's nothing in this year's regs that specifies what the steering input should be and exactly how that should change the toe angle. If you want to understand how it's legal, compare this year's regs to next year's. Time to accept it and move on.enri_the_red wrote: ↑22 Feb 2020, 10:08I'm going back to the question I asked 2 days ago about the possibility that using the DAS might break the parc fermé rule.
1- If you think that changing the toe angle is not a suspension configuration change, would you allow the mechanics to change it by working on the steering box or moving it?
2- If the toe angle is not a suspension setup parameter, does it mean that the steering arm is not a suspension member an therefore does not count towards the six suspension members limit defined by art. 10.3.5?
Brake Balance - Front/RearLM10 wrote: ↑22 Feb 2020, 16:42What's that?Mark4211 wrote: ↑22 Feb 2020, 16:37They have started using other BBAL offset values apart from .5%.
They used to only be able to adjust brake balance in 0.5% increments. A displayed value of 56.8% suggests that they have lowered the increment to 0.2% or 0.1%.LM10 wrote: ↑22 Feb 2020, 16:42What's that?Mark4211 wrote: ↑22 Feb 2020, 16:37They have started using other BBAL offset values apart from .5%.
You missed my point. The size limit reg you mention is 10.3.3. A steering arm is not a suspension member anymore, if this DAS is legal, so 10.3.3 doesn't apply.henry wrote: ↑22 Feb 2020, 13:10They do. Up to the size limits in the regs. And they change the incidence with steering angle using a cam on the hub end ball joint. @Platinum Zealot posted about this recently.zac510 wrote: ↑22 Feb 2020, 11:46Great point. And 10.3.3; Let's put a huge wing on that steering armenri_the_red wrote: ↑22 Feb 2020, 10:082- If the toe angle is not a suspension setup parameter, does it mean that the steering arm is not a suspension member an therefore does not count towards the six suspension members limit defined by art. 10.3.5?
i don't see the issue, i don't believe there is any rule as for how far the steering wheel needs to be in or out, nor the mandatory toe angle for the wheels. also, i think it's an impossibility, as under braking, the steering wheel goes into it's 'original' position, so the only moment there is any 'alignment' diferences is when the driver pulls the steering wheel at the straight, under a certain amount of force. when that force is no longer extorted, then the steering wheel returns to it's 'normal' position.
Rules about suspension elements. There are allowed to be up to 6 elements per wheel. My expectation is that these are: two for the upper wishbone, two for the lower, one push or pull rod and one for the track rod (steering arm). The regulations don’t specify these and other configurations that meet these rules would have to be allowed.enri_the_red wrote: ↑22 Feb 2020, 14:47rules about the steering or rules about the suspensions?
I think Scarabs mentioned in the video he did for Peter Windsor, that he thought this was by design for performance and for safety reasons.
Thanks! And also thanks @vogonvader.dans79 wrote: ↑22 Feb 2020, 17:01They used to only be able to adjust brake balance in 0.5% increments. A displayed value of 56.8% suggests that they have lowered the increment to 0.2% or 0.1%.LM10 wrote: ↑22 Feb 2020, 16:42What's that?Mark4211 wrote: ↑22 Feb 2020, 16:37They have started using other BBAL offset values apart from .5%.
Or they might have preset increments, maybe adjusted for the specific track. Watching on-boards should clear this. (I haven't watched much of them yet.)dans79 wrote: ↑22 Feb 2020, 17:01They used to only be able to adjust brake balance in 0.5% increments. A displayed value of 56.8% suggests that they have lowered the increment to 0.2% or 0.1%.LM10 wrote: ↑22 Feb 2020, 16:42What's that?Mark4211 wrote: ↑22 Feb 2020, 16:37They have started using other BBAL offset values apart from .5%.
Typically an F1 car will be set up so that its front wheels are aligned with ‘toe-out’, which simply means that they splay out at the bottom away from the centre of the car, with the top pointing inwards.
