They are pretty confident that they are either legal, or that they can overhaul and points they loose from being excluded.
It's both illegal and legal, it will be based on how convincing the teams arguements are.
They are going to need a better argument than that, as the driver turning his head, or the wheels has an aerodynamic effect.
I think that all technical protests should be lodged at the start of the event so that the teams have a chance to make changes if found to be in breach. Doing it afterwards is cowardly, it seems to me. As he says above "for max damage", rather than "to ensure legality".Engineers expect the protest to be lodged either after quali or race for max damage.
The counterarguments of amus are really idioticRZS10 wrote: ↑11 Mar 2020, 17:42AMuS had an article with 4 possible arguments against DAS (and Merc's viewpoint on why they're wrong) late February (haven't seen any links to it) ... i guess they've been argued to death in this thread already
1. It's moveable aero - Merc argues that it's a steering system, so it's the same as any other steering motion.
2. Breaking parc-fermé, specifically changing the setup of the car whilst driving during quali - Merc argues that it's no different than changing the brake balance, diffs or any other setting on the steering wheel, all 'setup changes' done via steering wheel are legal
3. It's changing the suspension config. - same as with 'normal' steering, it will always change toe, camber and as a result the ride height
4. Steering is for steering, turning the wheel is supposed to change the car's direction (supposedly RBRs fav. argument) - Merc had extensive conversations about that particular detail with the FIA, arguing that any steering system would have a dead zone/play, therefore turning the wheel would not always result in change of direction.
Changing the toe angle is not a change in the suspension geometry. Toe has no effect on how the suspension works.
It's actually a very good arguement, changing the toe angle will change the ride height of the car moving all the aero parts on the car almost like active suspension. This could be used to reduce drag and downforce on the straights then increase it for the corners like DRS.
I suspect it s the camber Angle that affects the height... The Toe effect on height Is negligible...Maplesoup wrote: ↑11 Mar 2020, 19:13It's actually a very good arguement, changing the toe angle will change the ride height of the car moving all the aero parts on the car almost like active suspension. This could be used to reduce drag and downforce on the straights then increase it for the corners like DRS.
The drivers head and the wheels aren't aero devices thus don't matter if they are moving.
Also worth noting that Merc argue the steering wheel is being used to adjust the wheels, when it actual fact it's the steering column that looks to be moving and be the key player in the system.
