What people don't seem to get is that your seasonal flu has killed over 20,000 people in the U.S. this year alone.Anyone who thinks "another flu" isn't scary doesn't realize
IF you have compromised health then any flu can be deadly.
Just looking at the number of “closed” cases is scary enough, given the converging rate of deaths vs recovered and the outcome of the rest still unclear.
You confuse people disagreeing with you as "not getting it".
No...they also cancelled everything through April!
For the early part of the outbreak the services will not be overloaded and specialist beds will be available for a higher % of needy cases, but as numbers go up, the line between needing specialise beds and those not getting them will lower so more and more will not be treated as the facilities are plain not available.Phil wrote: ↑14 Mar 2020, 00:09Just looking at the number of “closed” cases is scary enough, given the converging rate of deaths vs recovered and the outcome of the rest still unclear.
People should go back 14 days to what Italy was at the point rest of Europe is now. Fatality rate is yet to go up in all our countries once those that are infected have gone through the stages of the illness and as more cases surface, the less resources will be around to help.
2 weeks ago, most of us were going by daily life and our usual business.
Your analysis tells us what we need to do.Big Tea wrote: ↑14 Mar 2020, 00:34For the early part of the outbreak the services will not be overloaded and specialist beds will be available for a higher % of needy cases, but as numbers go up, the line between needing specialise beds and those not getting them will lower so more and more will not be treated as the facilities are plain not available.Phil wrote: ↑14 Mar 2020, 00:09Just looking at the number of “closed” cases is scary enough, given the converging rate of deaths vs recovered and the outcome of the rest still unclear.
Probably many of those that die in later days would have survived if the services were as available as in early cases.
Again, far easier to do early in the outbreak. As time goes on people get more used to the 'risk' and get sloppy or inattentive. Its human nature that urgency wears off with time.henry wrote: ↑14 Mar 2020, 00:46Your analysis tells us what we need to do.Big Tea wrote: ↑14 Mar 2020, 00:34For the early part of the outbreak the services will not be overloaded and specialist beds will be available for a higher % of needy cases, but as numbers go up, the line between needing specialise beds and those not getting them will lower so more and more will not be treated as the facilities are plain not available.Phil wrote: ↑14 Mar 2020, 00:09
Those of us at higher risk need to work hard at not being exposed to potential carriers.
Those at lower risk need to work hard at not infecting those at higher risk.
This could well end up being compounded by the fact that it doesn't seem to be that serious for most of the population. And it's ability to spread before showing symptoms makes it very difficult to stop spreading to the high risk people. You could easily end up with a situation next winter if this is seasonal were people who got it this time round basically don't care as feel they won't be that badly affectedBig Tea wrote: ↑14 Mar 2020, 00:53Again, far easier to do early in the outbreak. As time goes on people get more used to the 'risk' and get sloppy or inattentive. Its human nature that urgency wears off with time.henry wrote: ↑14 Mar 2020, 00:46Your analysis tells us what we need to do.Big Tea wrote: ↑14 Mar 2020, 00:34
Some virsuses have long term effects in the body so it's best not to get it at all.adrianjordan wrote: ↑13 Mar 2020, 18:29I may be showing my cynical side here, but I suspect the governments of the world would be less worried if we didn't have social media spreading so much hysteria and the mass media feeding that hysteria. After all, in most countries they want to keep getting elected and so are reacting as the public demands to some extent.Just_a_fan wrote: ↑13 Mar 2020, 18:12Would Govts of the world be less worried about COVID-19 if the Spanish Flu pandemic of 1918-20 hadn't happened?
Would Govts of the world have reacted as they have if coronavirus had quietly slipped out of Wuhan province?
Is the similarity between COVID-19 and SARS the real worry for Govts? SARS had a high mortality rate - up around 10%. MERS, of course, was much higher at about 33%.
I'm actually in favour of the British government approach of allowing some spread to help develop herd immunity and focusing efforts on slowing the spread and protecting at risk groups to limit mortality.
The problem with the China and Italy models is that you don't build immunity and can see a secondary spread when everyone comes out of isolation and there is still a small number of carriers there.
Yeah, well in that scenario you'd have a 4 car Ferrari/Alfa championship.Pyrone89 wrote: ↑14 Mar 2020, 02:36And the world economy crashing at a rate faster than in the big crisis of 2008, after which Honda, BMW, Renault and Toyota left is also looming. Basically this could mean RB and Merc pulling out and the Ferrari drivers suddenly sitting in the most wanted seat. Verstappen will then be kicking himself for commenting on Ferrari.
Number of deaths divided by number of closed cases will, in the first phase, be an overestimation and show very high fatality rates. Death appears much faster than recovery, especially when a patient is called recovered only after 2 negative tests which seems to be the case as of yet.Phil wrote: ↑14 Mar 2020, 00:09Just looking at the number of “closed” cases is scary enough, given the converging rate of deaths vs recovered and the outcome of the rest still unclear.
LM10 wrote: ↑14 Mar 2020, 03:04Number of deaths divided by number of closed cases will, in the first phase, be an overestimation and show very high fatality rates. Death appears much faster than recovery, especially when a patient is called recovered only after 2 negative tests which seems to be the case as of yet.Phil wrote: ↑14 Mar 2020, 00:09Just looking at the number of “closed” cases is scary enough, given the converging rate of deaths vs recovered and the outcome of the rest still unclear.
On the other hand, number of deaths divided by number of total cases will be an underestimation obviously. So the real number will be something in between.
But I absolutely agree with you on the scary part and I totally think that very strict measurements are needed. The faster the better. Even a 1 day sooner or later social distancing will have a very big effect - in numbers 40% less cases after 14 days!
This article is where I have that number from. It's a very detailed analysis on the spread of cases, effect of measurements (especially asian countries with 2003 SARS experience vs. western countries), estimated death rates etc. Highly recommended.
https://medium.com/@tomaspueyo/coronavi ... d3d9cd99ca
