trinidefender wrote: ↑26 Mar 2020, 01:22
And so did Honda's first iteration of their ICE. Both manufacturers quickly got rid of that solution as they realised equal length headers was the better solution.
One team won the first PU era WCC with a log, the others first PU attempt was total bollocks. Perhaps Mercedes were sandbagging with the 2014 PU and changed to tuned lengths for the impending power war? I'm not sure, but there are benefits of log style, like packaging, shorter paths, etc..
A wet intercooler (I assume you mean water to air intercooler) doesn't have to be placed in the V. The engineers can place it anywhere they choose so this point is moot.
Yes, water to air. Isn't the Ferrari unit mounted above the vee? How is this moot?
The headers being in the V would be a considerable bit higher up than where they are now currently at the very bottom of the PU. Ergo the weight is shifted upwards. This seemed fairly self explanatory.
Seriously, everyone knows what you meant...
And in a hot vee everything usually on top of the engine shifts down...
You also haven't addressed any of the other issues such as hot headers being around the very sensitive MGU-H, which already seems to be a fickle part, and other sensitive components. The issue of airflow in that region when there is already a lot of airflow coming through the sidepods that would be wasted.
I have, in other posts abd in my original posts, but I'll touch on them again.
The H can be fore or aft the vee, it doesn't have to be mounted in the vee, so this point is moot. What other sensitive equipment would be mounted up high that can just as easily be mounted below? Perhaps they could vent the vee from the roll hoop intake and out through a chimney, just as they do now?
I have already stated that I agree a hot vee setup could compromise the aero that currently flows under the side pods, but that was someone elses point.
The only absolute reason no PU era car has ever had a hot vee is because that is what is prescribed in the rules.
As Holm pointed out, two LMP1 cars were hot vee, both designs won championships.
Formula 2 engines are hot vee.
It's clearly not impossible...
