A. they're limited on CFD time too
I think I've seen somewhere that the Wind Tunnel is still working as well as the engineering side of the F1. What has been stopped is the production plant.
The whole Ges has stopped. Insiderscramr wrote: ↑16 Mar 2020, 13:30I think I've seen somewhere that the Wind Tunnel is still working as well as the engineering side of the F1. What has been stopped is the production plant.
Working remote should be possible if they manage to get some secure connections to the internal servers via Internet. They do that for the races so should not be a big drama to move some services to the racetrack servers. The question is if the servers can manage such increase in traffic
So what they are suggesting is Ferrari has a Semi-DAS basically?ScrewCaptain27 wrote: ↑26 Mar 2020, 21:24The “variable Ackermann” system as used by Mercedes is apparently on the Ferrari too, according to Giorgio Piola!
Source (Italian) https://it.motorsport.com/f1/news/f1-fe ... 0/4773419/
From what i understood it's linked to how much the driver steers, progressive ackerman, 45 degree angle steering input you get a certain level of action, 90 degrees and you get "more ackerman" and so on... which is sure to have an effect on how they set up toe.PlatinumZealot wrote: ↑27 Mar 2020, 21:13So what they are suggesting is Ferrari has a Semi-DAS basically?ScrewCaptain27 wrote: ↑26 Mar 2020, 21:24The “variable Ackermann” system as used by Mercedes is apparently on the Ferrari too, according to Giorgio Piola!
Except this might be more advanced but not driver controlled.
This too would be banned acording to the proposed regs.
You don’t need parts on the upright. All you need to do is vary the location of the inboard rose joint in relation to the rack. A simple swash plate/screw on each end of the end of the rack would do it. Then some levers or cams or whatever connected to the steering column can vary the Ackerman by rotating the swash and affecting the toe.PlatinumZealot wrote: ↑28 Mar 2020, 05:40The driver cannot vary its response is what i meant.
Are passivley moving parts allowed on the upright I wonder? Reason why i ask because to vary the ackerman either its the rack or the upright has to have extra moving parts. It is hard to see how Piola got evidence that the rack is split into two (or has varying width as does DAS)... Rumours? Otherwise it would be the upright has an extra joint to the steering knuckle... Hmm
I have an idea. Will make a new thread.
