@Machin: could you please update Virtual Stopwatch with the new tracks?
@Newcomers: don't forget to use Machin's software for each race to understand what direction to give to your project (accent on downforce, efficiency, speed,...).
yinlad wrote: ↑04 Apr 2020, 12:08
hmm, I seemed to be missing around -0.4 Cl from the total compared to the manually summed figures.
And my Cd figure 'total' is double the summed parts. That, I can put to the porous surfaces, but I don't know that they would be causing 0.4 of lift
Are the wheels included in the count? Because otherwise that's where most of the missing lift is coming from.
@LVDH: It would be good to have wheels numbers included in the data sheet.
Joe7218 wrote: ↑04 Apr 2020, 10:08
I also get an error when i try and run the case, "Error: cannot run "runfile"!"
Same here. LVDH said it's probably fixed in the new MFlow update, so let's just wait a few hours(?).
