someone, i think Jean, said there needs to be a certain mood before people will accept a fun activity like F1, even with no crowd, and i suppose he's right, now you point out this stat
Terrifying when you look at it that way.
Sadly it’s approaching 0.1% of New York State, population 20million. I don’t think NYC is reported separately, but with a much higher population density for its 10 million inhabitants than the rest of the state I would expect NYC to be higher than 0.1%. And like almost all reporting agencies this will be an underestimate not including those outside of hospitals and other medical establishments. This shows that when it takes hold the virus is extremely dangerous and measures to relax social distancing in the future will need to be very carefully monitored so that we can lock down again if there are flare ups c
This is a subject of debate, WHO is yet to clarify which death it to be exactly contributed to COVID-19 so I would take this numbers with a grain of salt.... When you have health issues, when you are chronically ill for years, a seasonal flue or a cold can cause your entire immunity to crash and then unfortunately you can die as a result of the same since your body can not longer fight...henry wrote: ↑19 Apr 2020, 22:59Sadly it’s approaching 0.1% of New York State, population 20million. I don’t think NYC is reported separately, but with a much higher population density for its 10 million inhabitants than the rest of the state I would expect NYC to be higher than 0.1%. And like almost all reporting agencies this will be an underestimate not including those outside of hospitals and other medical establishments. This shows that when it takes hold the virus is extremely dangerous and measures to relax social distancing in the future will need to be very carefully monitored so that we can lock down again if there are flare ups c
I think that's because those countries could also be lacking in testing, meaning they only test the worst cases (hence the high death ratio).PlatinumZealot wrote: ↑20 Apr 2020, 03:52Most other countries flounder in the sixites region. Means good luck if you are ever hsopitalized for Covid-19 in those countries!
I think population density for an entity, country in the example you’re citing, is only really relevant if it is a good proxy for the degree of association between its population. A better proxy might be the proportion of the population that lives in urban areas. Even then, as soon as measures are taken to disconnect areas of population the metric would fail.
Yes. I think the main problem is that; Lets say a country has a limited capacity or number of tests to complete 10'000 tests per day. That's not an awful lot and not sufficient in a one that has a very high density and the spread is higher. Sooner or later and you will be limited by the number of tests you can do. A percentage of all cases will die anyway - that's just the way it is. If you are limited by the number of tests, the fatalities will be skewed to look higher as you are not testing everyone. The result is a higher CFR.
yes there are so many ways the numbers vary, i don't think they mean anything at this point. If you have lots of hospital beds and testing you put milder cases in them and so your survival rate is higher. It might mean you're saving more or it might not. Some types of death get recorded as covid in some countries and not others, and then there are time lags, and on top of all that there's the age thing that is such a factor and multiple issues so often it's a question whether the death is really caused by covid or just hastened and by how muche30ernest wrote: ↑20 Apr 2020, 04:28I think that's because those countries could also be lacking in testing, meaning they only test the worst cases (hence the high death ratio).PlatinumZealot wrote: ↑20 Apr 2020, 03:52Most other countries flounder in the sixites region. Means good luck if you are ever hsopitalized for Covid-19 in those countries!
