Just_a_fan wrote: ↑13 Jun 2020, 16:30
Yes, but the fact they're going to turning left at the exit means the line through 4 will change.
I do not think so...looking at the video, turn 4 is defined by the outside apex behind and this will not really change. Turn 5 in this layout with a current car will not be an issue, which would compromise turn 4 in any way.
Just_a_fan wrote: ↑13 Jun 2020, 19:41
Yes, without T1/2/3, there is basically nowhere to over take. The "oval" is basically a much less interesting Hungaroring. I bet the drivers would be bored driving it.
That is absolutely true. With the layout with only one quick turn after the start/finish, this would be a non-overtaking track. You have three to four turns in which you can not follow in the upper part in the track map and then another quick one at the best overtaking opp. With the standard T1/2/3 layout one can get closer on the two straights, stay very close in T1/2/3 and overtake into turn 4. Or even have battles like Ros/Ham where the lead changes twice.
FW17 wrote: ↑13 Jun 2020, 20:11
It is going to be 50 second lap, there will be plenty of overtaking with cars getting messed up in the traffic.
The track has a length like Adelaide or just 10% less than Indy...with much better overtaking opportunities. I do not think that traffic will be too bad.
Why spoil a good layout with a hair pin? When drivers can figure out an overtaking into copse and Stowe of Silverstone (which is a lot more exciting than at a hairpin) and drs making overtakes less memorable, I crave for battles that would last a dozen laps (quiet possible with a short lap and plenty of straights to relax those pirellis).
There will be no battle without a hairpin. It would be all quick corners, no way to relax the tires as the following car would suffer dirty air. We will see again a big dirty air problem this year and longer...unfortunately the reg change is not coming, so forget about following close over many laps.
The oval layout with a quick T1 is similar to T1 in Hockenheim...nothing happening there...
