Mercedes W11
LM10
LM10
127
Re: Mercedes W11
zibby43 wrote:
10 Jul 2020, 20:43
Any thoughts on why the Merc’s looked relatively underwhelming compared to last week? Particularly with HAM’s car?
No one at Merc seemed that concerned about the performance, other than saying there were stumped by HAM’s car’s performance in certain corner types.
HAM was in a light mood, though, talking about a “dry dance” for tomorrow.
Ignore the first tweet.
Talking about Mercedes, maybe that was their issue.
Sempre Forza Ferrari
F1Krof
96
Re: Mercedes W11
LM10 wrote:
11 Jul 2020, 09:15
zibby43 wrote:
10 Jul 2020, 20:43
https://twitter.com/Vetteleclerc/status ... 5438900226
What too much downforce? :wtf:
Wroom wroom
Drica
Re: Mercedes W11
Most likely being too harsh on the kerbs and punishing the suspension in high-speed sections while the car is loaded in a turn
zibby43
zibby43
Re: Mercedes W11
LM10 wrote:
11 Jul 2020, 09:15
zibby43 wrote:
10 Jul 2020, 20:43
Thanks for the info. Looks like that may have been a separate little issue for both of the drivers.
Per AMuS, Hamilton himself, and other sources, Merc found mechanical issue with HAM's car overnight and they rectified it today prior to quali. They just opted not to give away the details.
On a side note, pretty nice hi-res overhead shot:
Image (credit: Ellios)
Re: Mercedes W11
zibby43 wrote:
11 Jul 2020, 23:14
https://i.imgur.com/IakI2vZ.jpg (credit: Ellios)
You can see the Y250 vortex.
SiLo
145
Re: Mercedes W11
Just_a_fan wrote:
12 Jul 2020, 01:13
zibby43 wrote:
11 Jul 2020, 23:14
You can also see where the floor pushes air away behind the rear tyre to keep the flow along the edge clean.
Felipe Baby!
ENGINE TUNER
ENGINE TUNER
25
Re: Mercedes W11
Does anyone know how the "brake magic " works? Is it a type of "line lock" system?
ENGINE TUNER
ENGINE TUNER
25
Re: Mercedes W11
ENGINE TUNER wrote:
03 Jul 2020, 04:15
This seems like the biggest change/update on the car. Is it something track specific where they may revert back to the previous diffuser in Hungary or afterwards? Was this change made for more rear downforce or less drag? Or maybe a more stable platform? Does any other team run a similar diffuser already? Is it a copy or an innovation?
Anyone? ??
NoDivergence
NoDivergence
52
Re: Mercedes W11
ENGINE TUNER wrote:
12 Jul 2020, 03:30
Brake magic isn't anything near as glamorous as it sounds. It's like a default setting for brake balance. Reduces driver workload through the lap to go to a preset brake balance for certain sections of track
NoDivergence
NoDivergence
52
Re: Mercedes W11
ENGINE TUNER wrote:
12 Jul 2020, 03:32
ENGINE TUNER wrote:
03 Jul 2020, 04:15
Anyone? ??
Nobody here has CFD eyes
ENGINE TUNER
ENGINE TUNER
25
Re: Mercedes W11
NoDivergence wrote:
12 Jul 2020, 03:52
ENGINE TUNER wrote:
12 Jul 2020, 03:30
Guess the driver would just have to drag the brakes to build up brake and tire temps then.
pierrre
pierrre
56
Re: Mercedes W11
LM10 wrote:
11 Jul 2020, 09:15
zibby43 wrote:
10 Jul 2020, 20:43
doubt it was the gearbox that was an issue with the austrian grand prix curbs, was always the suspension. theyve got a reversed torque arm that is mounted to the rear crash structure and maybe it is this area that they want to conserve. got strong suspicions they are being very clever with that, w11, rear suspension in regards to running a long wheelbase chassis that is more prone to understeer in slower corners..last season, those curbs did not get the team to send warnings to the drivers
zibby43
zibby43
Re: Mercedes W11
Just_a_fan wrote:
12 Jul 2020, 01:13
zibby43 wrote:
11 Jul 2020, 23:14
Indeed - there are all sorts of little surprises in this photo!
pierrre
pierrre
56
Re: Mercedes W11
zibby43 wrote:
11 Jul 2020, 23:14
LM10 wrote:
11 Jul 2020, 09:15
zibby43 wrote:
10 Jul 2020, 20:43
possible breakdown open for criticism or discussion
Pyrone89
Re: Mercedes W11
pierrre wrote:
12 Jul 2020, 07:05
zibby43 wrote:
11 Jul 2020, 23:14
LM10 wrote:
11 Jul 2020, 09:15
https://scontent.fbki1-1.fna.fbcdn.net/ ... e=5F2EF8B1
Looking at that they seem to be able to create massive amounts of outwash, something thought to have been impossible with these post -2019 front wings. This then enables them to very effectively seal not just the immediate area around the back but a whole area around it, creating massive rear downforce like if they were driving with small skirts. You can also see there is very little air going from the rear wheels under the diffuser. It is going straight back. It is also a heads up on 2021: they apparently don't need the floor edges to effectively seal because of the big outwash. For 2021 this means they will not lose as much downforce as competitors that do not have this outwash and rely on the floor edges (that are going to get cut big time) to do the sealing. Basically this car is 2021 proof. Very impressive engineering and points to why this car is so good in all conditions.
