Mercedes W11
Holm86
247
Re: Mercedes W11
WaikeCU wrote:
17 Jul 2020, 10:20
Holm86 wrote:
17 Jul 2020, 08:14
shady wrote:
17 Jul 2020, 06:17
Whats with the red light in the garage?
Might be a light that makes flow Wiz easier to see
Can't be flow viz I think, since the car hasn't run on track yet.
Maybe a symbolic way of Lauda's spirit watching over the car as he's been part of the team's current success era.
Doesnt matter if they havent run yet, could just be to test the light before practice.
But yes, it could also be to spot hydraulic or coolant leaks
astracrazy
astracrazy
31
Re: Mercedes W11
I presume this is what they are referring to. In the pics it looks like they are doing some sort of tests/instillation.
Holm86
247
Re: Mercedes W11
astracrazy wrote:
17 Jul 2020, 15:40
Mystery solved =D> :D
SiLo
138
Re: Mercedes W11
So apprently Mercedes are running their "normal" front suspension this weekend which is lighter than what they ran in Austria. They had to beef it up for the kerbs there as they were worried they would get a suspension failure.
Quite interesting, seems the kerbs there are quite a lot worse than most other tracks!
Felipe Baby!
atanatizante
115
Re: Mercedes W11
astracrazy wrote:
17 Jul 2020, 15:40
Maybe they mean W11 car :wink: ...
Jesus
santos
santos
Re: Mercedes W11
atanatizante wrote:
17 Jul 2020, 16:47
astracrazy wrote:
17 Jul 2020, 15:40
It's a post from 2018...
Re: Mercedes W11
AMuS
Re: Mercedes W11
Oooh. It has a "T" wing under the rear upper wishbones!
Trailing rear lower wishbone is mounted very high to the gearbox to free up the airflow running under the gearbox.
ENGINE TUNER
ENGINE TUNER
25
Re: Mercedes W11
Holm86 wrote:
17 Jul 2020, 08:14
shady wrote:
17 Jul 2020, 06:17
Possibly something to let them know that a part of the electric ERS system is being worked on.
aleks_ader
90
Re: Mercedes W11
17 Jul 2020, 17:36
I guess that is T wing loophole right? Its similar like Williams tried out in 2017 with multiple t wings. But i m surprised if that legal box is so low.
Re: Mercedes W11
Here you can see it better. Btw also present on the W10.
Re: Mercedes W11
MtthsMlw wrote:
17 Jul 2020, 18:41
https://f1tcdn.net/gallery/var/resizes/ ... 21/103.jpg
RP20 has it too :D
From your own post in comparison thread
holeindalip
holeindalip
Re: Mercedes W11
Morteza wrote:
17 Jul 2020, 23:39
MtthsMlw wrote:
17 Jul 2020, 18:41
RP20 has it too :D
https://imgr1.auto-motor-und-sport.de/L ... 707522.jpg
Well those parts are purchased from Mercedes so I would hope they would be in there.....
zibby43
zibby43
613
Re: Mercedes W11
Practice start + DAS usage in Hungary.
Man, does the car sound good here.
Re: Mercedes W11
Is there not more tyre grip available with DAS engaged?
EDIT: For the race start I mean; so DAS engaged off the line?
