That’s not the PCU, they’re too small and the wiring too thin. I am guessing the data acquisition units for the cars initial testing.
I saw the Toyota KERS hardware laid out on a bench at Portimao. The Power Control unit (PCU) is much larger box, about 30cm x 20cm x 10cm. While the Motor Generator (MGU) is only about 15 long and probably slightly less in diameter. It was the battery that I found curious, it was an unusual shape, moulded into a arc, like a flat bottomed orange segment. This must be to make it fit between the rad ducting and monocoque. I saw the water cooling pipes for the MGU but not the electrical cables which need to run ten of amps at high DC voltage, I am told these are quite serious bits of cable.
From what I’ve learned from the teams; the MGU\PCU\battery will all be directly connected. The SECU will control the PCU via its usual CAN interface. The FIA will use the SECU to check that KERS has been instigated for the maximum time and has stored the maximum energy each lap, then a FIA torque sensor will detect the power re-transmitted through the drive train.
See if I can popularize tis correctly scarbs,
The FIA will monitor BOTH the electrical energy going from the MGU to the battery during breaking, as well as the mechanical energy leaving the MGU during accelleration?
outstanding bits of information scarbs, thank you, we as fans should be able to get more info like this, but sadly(but understandably) the teams are not putting it out there for everyone to see.
Thank's scarbs! Now as for the practical use of KERS, do you figure that teams will arrange things as charging is triggered by pressing the brake-pedal and discharge by a push-thing on the steering-wheel? Or will it be a little more sophisticated than that?
xpensive wrote:Thank's scarbs! Now as for the practical use of KERS, do you figure that teams will arrange things as charging is triggered by pressing the brake-pedal and discharge by a push-thing on the steering-wheel? Or will it be a little more sophisticated than that?
modbaraban wrote:Can it be possible under current rules to use KERS to control braking or/and traction?
Nope, I checked with the tech directors and as the system is controlled by the secu any funny business under braking or accelleration is strictly forbidden.
