It's becoming increasingly unlikely that qualy modes will be banned for Spa.
I hear FIA have sent out a draft TD over the weekend for teams to review. This week FIA staff are on holiday so we won't hear anything until next week.
In case people understand them. That would mean trouble when they have to be enforced.
pretty much, if they actually published them the general public would probably tear them to shreds.
Correct. it is not like anybody can get any additional power-output over and above the point of max-fuel-flow rate.Big Tea wrote: ↑16 Aug 2020, 23:54There is no advantage to doing so now due to max fuel flow. If it became the new 'qualli mode' there would be. There would be higher wear rates, but it would have to be accounted as party mode is now.Mchamilton wrote: ↑16 Aug 2020, 23:50when did you last see an f1 car rev to 15k rpm though? i highly doubt they do any of their reliability testing etc based on any significant usage of such rpm.Big Tea wrote: ↑16 Aug 2020, 23:40
It would have 'party mode' equivalent up to 15k if needed without the driver having to switch anything. If it is not needed continue to change at 12.5.
A new ore in this came from Sam Collins in the Sky chat today. He recons the Merc is just too powerful for the tyres and is tearing them up. Did the suggestion of reducing modes come from them? They are not going to give away an advantage they can not use if someone else can use it. But if it is no good to them, stop anyone else getting it too
Thanks for the intel.
The problem with revving that high is the engines are optimised for the 10-12k region and power drops off above that.
I don’t know about additional engine revs, but the way I’m reading it drivers must complete a certain number of laps of the race with the engine mode used In quali
But do you have to hit maximum revs while the mode is engaged?the EDGE wrote: ↑17 Aug 2020, 23:11I don’t know about additional engine revs, but the way I’m reading it drivers must complete a certain number of laps of the race with the engine mode used In quali
So it doesn't say you can’t use a more-powerful mode during the race for say...overtake or hammer time
So party mode won’t really be banned in qualifying, but they’ll just have to use the same mode both in qualifying and race? If someone manages to build an engine capable of using max possible mode in qualifying and several laps in race without it breaking apart after only 3 races, they would be allowed to do so?the EDGE wrote: ↑17 Aug 2020, 23:11I don’t know about additional engine revs, but the way I’m reading it drivers must complete a certain number of laps of the race with the engine mode used In quali
No one outside of the teams has any idea what the fia is planning or if it will even go through.LM10 wrote: ↑17 Aug 2020, 23:43So party mode won’t really be banned in qualifying, but they’ll just have to use the same mode both in qualifying and race? If someone manages to build an engine capable of using max possible mode in qualifying and several laps in race without it breaking apart after only 3 races, they would be allowed to do so?the EDGE wrote: ↑17 Aug 2020, 23:11I don’t know about additional engine revs, but the way I’m reading it drivers must complete a certain number of laps of the race with the engine mode used In quali
I haven't the foggiest.. somehow I doubt FIA know either.
Related (but off-topic) - is the reason for fixing gear ratios per season also cost reduction? Or is there additional disincentive here that isn't clear to me.
