Conceptual wrote:See, this post by Ciro is exactly why it is not a bad thing to ask the same question again. By taking the time and effort to condense many pages of the previous thread, you have effectively created a very nice FAQ that will no doubt bring much traffic to this website over time.
I thank you for not n00bing this question, it was very informative!
I agree... bravo, Ciro!
One of the reasons I posted this thread was to look more into Ciro's mention of friction force being proportional to the 2/3 power of the load.
Ciro Pabón wrote:As Jersey Tom explains, what they're measuring is more the flexion of the tyre than the true contact area. So, for friction estimation purposes, is more or less a useless exercise. I'd say you're learning more about the flexion of the tyre and its "internal heat" generation than anything else, but I might be wrong.
I agree with you here, certainly. An unscientific method at best,
but the trends are still there.
However, I was curious about the relationship you could find from the figures given in the article linked by Shredcheddar. So, this is what I got in ten minutes, only for the first relationship between contact area and load shown in that article:
The relationship is not lineal, as the article states. The best fit I got is:
The coefficient of correlation squared (
![](/cgi-bin/mathtex.cgi?r^2)
) is 0.994, which is pretty good.
Conclusion: this is a "very strong" potential relationship (by potential, I mean a relationship of the form
![](/cgi-bin/mathtex.cgi?Y=b*X^m)
, I'm not sure about the english term), because the exponent of X is 0.3. This means that for very high loads the area does not increase significantly, which is reasonable.
I intended to look at those trends when I got home today, so perhaps I will try to match your contribution.
Finally, I find curious (but not conclusive in any way, it's just a correlation) that the patch area is roughly proportional to the cube root of the load. I was expecting an exponent of 2/3,
as we discussed in the previous thread.
Ciro, something I wondered when you posted that was a more exact meaning of the relationship you stated. What I mean is, you said friction
force is proportional to the 2/3 power of load. You explained that the apparent linearity of friction with load (for metals) was attributed to the fact that real contact area changes as a function of load. Based on that statement,
I still don't really understand the nature of real contact area's effect on friction. I understand that it changes with load, certainly, but mathematically I don't understand how to interpret "friction force is proportional to the 2/3 power of load" with respect to area, when at the same time metallic friction
appears linearly related to load.
Follow me on a little mind-trek that probably doesn't make any sense. I'm operating on some assumptions that are confusing and probably wrong:
I remember thinking that if you meant friction was proportional to the 2/3 power of
normal stress, that leaves room for a term expressing real contact area as a function of load; more specifically, proportional to the 1/3 power of load.
Robert Smith, in his book
Analyzing Friction in the Design of Rubber Products and Their Paired Surfaces, defines the metallic coefficient of friction
![](/cgi-bin/mathtex.cgi?(u))
as the ratio of the bulk shearing stress
![](/cgi-bin/mathtex.cgi?(Tau))
of the material divided by the bulk yield stress
![](/cgi-bin/mathtex.cgi?(Sigma))
of the material.
So, do we have something that looks more like:
Which simplifies to:
![](/cgi-bin/mathtex.cgi?F = DL)
Where D is a unitless constant.
So, even in spite of that above (and perhaps
meaningless) mathematical manipulation, shouldn't we be looking for evidence that area is a function of
![](/cgi-bin/mathtex.cgi?L^{1/3})
? That seems to be a key trend.
All of this makes Ciro's finding very interesting. But wait, there's more of this
![](/cgi-bin/mathtex.cgi?^{1/3})
exponent.
I just read this last night, on page 20 of Robert Smith's
Analyzing Friction in the Design of Rubber Products and Their Paired Surfaces. Smith presents Schallamach's findings when testing the friction coefficient of sliding rubber versus the applied pressure:
Soft rubber:
He calls this an "empirical, Hertz-like equation" (for those of you familiar with Hertz's equation - I am not).
So there are some trends here. My mind is too mixed up with the alphabet soup of new information. But I will post this hoping that one of you can correct or guide me, or at the very least to archive my thoughts.
So, as a disclaimer,
I probably have everything mixed up. That thought process above resulted from an assumption that Ciro was talking about metallic friction and its apparent linearity with load, and my attempt to figure out how two quantities could vary non-linearly and still appear linear when combined. A very reverse-engineered derivation with a lot of holes, I'm sure.
Phwew. Not exactly something to wind your mind down on after work. I've got a headache... time for some tea.
![Razz :P](./images/smilies/icon_razz.gif)
