The FIA came up with this on the fly, it will probably be a complete mess!El Scorchio wrote: ↑03 Sep 2020, 17:59If it makes overtaking any harder, then it's going to be a complete disaster.
Seems like, but if they will run the engine harder anyway, it probably will not me that much of a drop.dans79 wrote: ↑03 Sep 2020, 17:37From what little detail I can find it basically sounds like ice parameters cannot be changed. Thus, in out an overtake will probably just be changes to the electrical Modes.Big Tea wrote: ↑03 Sep 2020, 17:34If you have to run the same mode in the race as in qualifying, it is by definition no longer 'qualifying mode' is it? as it is used in the race it is race mode.
From here on in I get problems following. They will be allowed to have an in/out lap mode, and an overtake button, and a 'rapid recharge' mode, and possibly others we will not go into like limp mode.
So how does a combination of inlap mode, presumably not recharging, and overtake button, presumably top engine mode, differ from 'party mode'?
I think it's like parc ferme - it comes in to play as soon as qualifying starts. From driving on to the track in Q1 until the flag drops at the end of the race, the "one mode to rule them all" (*) rule applies.
In practice they can vary the settings seeking out the one they will deploy from qualification on. Just like any other setup change.
The same modes may be used to defend overtaking. I am not that pessimistic in rules change influenceon the overtaking.El Scorchio wrote: ↑03 Sep 2020, 17:59
It's ok it has a nice ring to it.Just_a_fan wrote: ↑03 Sep 2020, 18:48"one mode to rule them all" (*) rule applies.
(* - with apologies to Tolkien fans)
thanks, makes sense, also because on Friday often a completely different engine is used.
All teams can use different modes etc. The mode is for a team not an engine manufacturer.search wrote: ↑03 Sep 2020, 20:22thanks, makes sense, also because on Friday often a completely different engine is used.
I still struggle to see how it's going to work when engine-age varies though. If, for example, Williams goes to Abu Dhabi with a 5 race old engine, while Mercedes brings a new one, both will need to use the same mode - and it will probably be an aggressive one, as it's benefits the works team. That doesn't seem to make much sense to me.
At the moment (until anyone brings engine 3) it can vary, and I also see no real reason to stop that.
okay, then the AMuS article about it was wrong, it clearly stated "On from the third engine per season, all engines of one manufacturer need to be run in the same mode"siskue2005 wrote: ↑03 Sep 2020, 20:41All teams can use different modes etc. The mode is for a team not an engine manufacturer.search wrote: ↑03 Sep 2020, 20:22thanks, makes sense, also because on Friday often a completely different engine is used.
Real precious!Just_a_fan wrote: ↑03 Sep 2020, 21:25Big Tea wrote: ↑03 Sep 2020, 19:50It's ok it has a nice ring to it.Just_a_fan wrote: ↑03 Sep 2020, 18:48
(* - with apologies to Tolkien fans)![]()
Seems like meaning lost in translation.search wrote: ↑03 Sep 2020, 20:49okay, then the AMuS article about it was wrong, it clearly stated "On from the third engine per season, all engines of one manufacturer need to be run in the same mode"siskue2005 wrote: ↑03 Sep 2020, 20:41All teams can use different modes etc. The mode is for a team not an engine manufacturer.search wrote: ↑03 Sep 2020, 20:22
https://www.auto-motor-und-sport.de/for ... direktive/
What do you mean @Siskue? It was also on English sites.siskue2005 wrote: ↑04 Sep 2020, 08:43Seems like meaning lost in translation.search wrote: ↑03 Sep 2020, 20:49okay, then the AMuS article about it was wrong, it clearly stated "On from the third engine per season, all engines of one manufacturer need to be run in the same mode"siskue2005 wrote: ↑03 Sep 2020, 20:41
Ok, i had seen it only on other languagesWouter wrote: ↑04 Sep 2020, 08:52What do you mean @Siskue? It was also on English sites.siskue2005 wrote: ↑04 Sep 2020, 08:43Seems like meaning lost in translation.search wrote: ↑03 Sep 2020, 20:49
"From the third engine per season, all engines of one manufacturer need to be run in the same mode"
