NathanOlder wrote: ↑13 Sep 2020, 00:36
nevill3 wrote: ↑12 Sep 2020, 22:16
I thought I saw that Lewis went out again in Q1 after a setup change
You can't change setup before a second run. Once you leave the garage for the first time in Q1, the setup is frozen.
There are limited changes that can be made as has been said, also Lewis in his post Qualifying interview mentions that he made some changes that helped between Q1 and Q2. I watched this video after I posted my original comment.
During qualifying I definitely noticed Lewis going out again where as none of the other top runners did. These little details were not commentated on on the live feed I was watching but the graphic on the screen showed Lewis was out a second time and his overall lap count is higher than the other top two.
