“Little Monegasque Kid” - what’s that supposed to mean? Your post implies being a skinny little monegasque kid means you cannot be a special talent. Which in other threads you have called Leclerc.PlatinumZealot wrote: ↑19 Sep 2020, 00:28I don't buy the excuse that he cant drive a loose car anymore. I have begun to believe that Vettel simply gets nervous when he has a fast teamate. He is essentially the racing version of the sprinter Asafa Powell.
I think Vettel’s style makes the rear looser. I think hes a hard trail braker. If you watched his laps on hard braking circuits, you can see the nose point so much better in those corners with heavy braking entries.
Case in point:
As an aside - you can also see what Jolle was saying in the T5/6 chicane - before hitting the T5 apex he’s already turning to focus on T6. Also in the tight uphill chicane (is it T8/9?) while he is increasing left lock for the kink in the corner his head is already looking for the right hand apex.
Anyways back to my point. If you see the main issues between Vettel and Leclerc this year for example it’s always been on the entry (more or less) when Vettel has these snaps. I think Lec brakes smoother and less of his corner is trail-transitioning into full corner grip, which keeps the snap locked up.
Vettel’s RB years I think they loosened the rear suspension (softer ARB, etc?) and allowed Vettel’s heavy trail braking to break into an induced roll-oversteer situation, and then when this helped the car change direction better, Vettel slammed the throttle and the added downforce from the blown floor squashed out whatever was left of a slide.
