Just to add up to my quoted post, apparently there is appendix in Sporting Regulations which ensures that the PU manufacturer with least number of customer teams has to supply PUs to the team that has found itself with no PU for their carsCuky wrote: ↑02 Oct 2020, 10:34Easy: others already have their capacities full with teams they supply.DChemTech wrote: ↑02 Oct 2020, 10:30Thing is then, why would Renault be forced? Why not one of the other suppliers? All three have their own factory team, so all three should be equally be able to choose who they deliver to, or be equally restricted in that choice.Restomaniac wrote: ↑02 Oct 2020, 10:20Looking at it. It’s going to be a situation where Renault are forced to supply. However you can be certain RedBull will just get given the engines with no input allowed.
Mercedes: works team, Williams, Aston Martin, McLaren
Ferrari: works team, Alfa Romeo, Haas
Renault: works team
https://www.racefans.net/2020/10/02/cou ... erstappen/Under appendix nine of the F1 sporting regulations the power unit manufacturer which has the fewest customers must be prepared to supply a team which has no engines if called upon to do so. If Red Bull don’t have a deal in place by June 1st next year, the FIA could therefore find itself in the extraordinary position of presiding over a shotgun re-marriage between Red Bull and Renault.
Thats the name i was trying to think of
Maybe Honda does not see any reason to be in a frozen engine formula when a competitor still has a big advantage and no PU parity has been achieved.
They are very lucky if Renault is compelled to supply them, given the way RBR threw them under the bus last time after their winning partnership came to an end. If I was Renault I'd try and seek any avenue to avoid having to do so.
I think RBR would see it as unlucky if Renault are compelled to supply them! If anything it might be strategically smarter for RBR to play to this stereotype and try to get FIA to mandate Mercedes supply them.El Scorchio wrote: ↑02 Oct 2020, 15:36They are very lucky if Renault is compelled to supply them, given the way RBR threw them under the bus last time after their winning partnership came to an end. If I was Renault I'd try and seek any avenue to avoid having to do so.
Well, it's an interesting one isn't it! Mercedes and Ferrari are under absolutely no obligation and would obviously fight anything the FIA tried to impose on them which there is probably no grounds for anyway. Merc aren't going to do their biggest competitor any favours even if it means them disapperaing and Renault are clearly going to do the least possible they are obligated to in any future relationship. If RBR somehow find themselves without an engine supplier they only have themselves to blame.nzjrs wrote: ↑02 Oct 2020, 15:40I think RBR would see it as unlucky if Renault are compelled to supply them! If anything it might be strategically smarter for RBR to play to this stereotype and try to get FIA to mandate Mercedes supply them.El Scorchio wrote: ↑02 Oct 2020, 15:36They are very lucky if Renault is compelled to supply them, given the way RBR threw them under the bus last time after their winning partnership came to an end. If I was Renault I'd try and seek any avenue to avoid having to do so.
I think this is probably a bigger reason for Honda to leave. Ferrari and Merc uses F1 as marketing but Honda traditionally uses F1 to train their engineers. In a frozen state, there is no more innovation and probably less attractive to Honda even though it would probably cost less. On the other hand, you can say once frozen, if you are not on top, then it is not attractive from a PR perspective either, no reason to keep playing.
What's the penalty for non-compliance should Renault not wish to supply the units?
https://www.fia.com/sites/default/files ... 6-19_0.pdfb) No power unit may be used in a given Championship season unless the Power Unit Manufacturer
supplying such power unit accepts and adheres to the following conditions:
