Honda leaving F1.
Re: Honda leaving F1.
Zynerji wrote: ↑
04 Oct 2020, 01:50
I miss the frozen V8 days, and I cannot believe that I just typed that...πŸ™„
I dunno.... In the V8 days.... There was no discussion of engine performance or upgrades ("reliability") other than cold blowing and hot blowing... It was all aero talk. Engines were boring. not much difference between them... Nothing much to talk about. But these turbo Hybrids really brought back the excitement to the engine side of things. That's what I love about this era.
I would love for another engine shake up soon even sooner than 2025.
adrianjordan wrote: ↑
04 Oct 2020, 11:31
Big Tea wrote: ↑
04 Oct 2020, 11:26
coaster wrote: ↑
04 Oct 2020, 11:10
Agreed, time to purge.
Let it all bankrupt and maybe from the ashes a new series may form.
You do not need to go that far, quit and promote F2 to the top
More likely Formula E.
That's where the future is headed eventually. Why not have F1 take the EV crown and run with it.
You would find VW Group, BMW, Honda and many more jumping at the chance to develop world beating EV motors with a sporty reputation.
I know it's not what petrol heads want, but it is coming and sooner than many of us could have imagined.
Yuck.. Anything slow and electric is not really pinnacle of motorsport. That's cheap marketing for manufacturers.
They spend a few dimes, and get "good, green PR", and maybe some appearance of road relevance.
Battery tech needs to be at least six times more energy dense before it reaches F1 levels of speed and endurance. I definitely don't want to see F1 go this way any time soon.
Big Tea
PlatinumZealot wrote: ↑
05 Oct 2020, 22:00
04 Oct 2020, 11:31
Big Tea wrote: ↑
04 Oct 2020, 11:26
But if it was not under Formal E regs, or ethos, it would not need to be slow. I am quite confident that if the regs said they could even today they could build an electric car to beat one of todays F1 who are within very tight limits.
Ok, range may put a spoke in it, but with a smaller battery pack than FE, constantly recharged from a 'unit' with strict emissions I think it would be close.
I say 'unit' as there are several ways to drive a generator with very tight emissions control. An ICE driving the car allong side would be even better.
BrunoH
BrunoH
bring back the v12 ... fk even the v8....
For Electic Formula 1. The weight is your elephant in the room. More weight needs more downforce and consumes more tyre life. Can do a basic estimate and add 1,000lbs of weight if we look at supercars. But lets havea deeper look.
With Current battery packs... 95kWh is about 365kg of battery.. Rimac has 120KWh.. Current 105kg of fuel is about 1200kWhr times 50% about 600Kwhr. So we need 5 to 6 battery changes per race. (assuming same car weight!)
The batter would be a massive thing taking up the floor and where the fuel tank would be... with best tech of 260Whrs/kg... And assuming a 120kWhr battery. That's about 460kg of battery. Not including the protective packaging itself.
Using the Rimac motors as an example of most powerful...
Put a 2X 350Kw motors side by side or in series for rear wheel drive. For 700kW total. Slightly weaker than today's power units in peak power but on the good side max torque can be had even from zero speed. Management of the massive motor torque would be interesting.
To give the tyres a hope and a prayer, maybe four wheel drive? But it might be too dangerous to put a motor in front of the driver. Maybe a metal structure or something have to be used to keep it.
Ok.. So lets stick to rear wheel drive. Say our double motors and gearbox weigh 160kg total for rear wheel drive. Thats about the weight of the current ICE coincidentally. Not counting bigger shafts needed for the torque. But cooling should be interesting. Should need less radiator. Maybe maybe not.
It means we are still about 450kg overweight. And we need five battery changes. Or five car changes?! Lol
Big Tea
05 Oct 2020, 23:40
Yeh, but apart form that it would be good ( :D )
What about a 1ltr ICE with much wider options than now and unlimited harvesting?
hUirEYExbN
Big Tea wrote: ↑
05 Oct 2020, 23:49
05 Oct 2020, 23:40
Or, how about the FIA say "Manufacturers, build whatever you want, just don't use more than X MJ of energy in a race." I'd say that's just as likely as fully electric or tiny engine F1 ... for now.
It'd be pricey, but it's not like the current engines aren't pricey.
Anyway, I think I'm off topic.
Mogster wrote: ↑
05 Oct 2020, 20:41
214270 wrote: ↑
05 Oct 2020, 13:15
Just_a_fan wrote: ↑
05 Oct 2020, 09:58
And Honda might have a head start on that thanks to their F1 involvement. Couple that with Indy only being a two-horse race in terms of engine supplier and Honda are probably thinking they've got a good chance to "do a Mercedes" in Indy.
Pretty sensible if you ask me. They have not been able to really stamp their presence on F1, but if they can then dominate another series with what they’ve been able to learn; good for them. The Indy exposure is not a patch on F1, but maybe that’s not so relevant.
Indycar’s KERS will be a spec unit bolted onto the ICE manufacturers (almost spec) current V8T. The car is a spec Dallara. There is very little technical development in Indycar these days.
Good info πŸ‘
tangodjango
tangodjango
Another interesting article:
THE FULL STORY OF HOW McLAREN STEERED HONDA TOWARDS FAILURE - https://the-race.com/formula-1/the-mcla ... l-failure/
β€œHamilton’s talent is perhaps even more than that of Ayrton or Schumacher or Fernando." - Rubens Barrichello
bigblue
tangodjango wrote: ↑
06 Oct 2020, 10:44
Thanks, good link, some interesting insights in there that clarify the early issues.
Juzh
161
05 Oct 2020, 21:55
Zynerji wrote: ↑
04 Oct 2020, 01:50
Top speed with 2022 cars which are predicted to have even more drag would be somewhere around 270 kmh on most tracks that require some downforce. Maybe even less. People just dont realise how crap those engines were power wise. Worst f1 engine ever. 2006-2008 was acceptable, but with 18k rev limit they were completely useless.
tangodjango
tangodjango
bigblue wrote: ↑
06 Oct 2020, 12:04
06 Oct 2020, 10:44
There are some technical inaccuracies such as the compressor never being entirely within the vee as suggested (this has been discussed in detail elsewhere on F1technical) but on the whole a good read.
Zynerji
111
https://www.motorsportweek.com/2020/10/ ... fter-2021/
Sounds like Honda is willing to help RBR even after they leave... 😲
El Scorchio
Zynerji wrote: ↑
06 Oct 2020, 13:34
Good news if so, and if it's workable.
Zynerji wrote: ↑
06 Oct 2020, 13:34
Begs the question of how much they'll help. Would they give them engines but not have their name mentioned at all? Would they help Red Bull develop the engine with a third party? It's a heck of a thing to say "we'll help in any way we can" having just pulled out of the game. It throws up a huge number of questions and scenarios.
