Don't forget that Albon was on a softer compound that was 25 laps newer than the tyres Max had on! Albon should have been way faster than Max not just matching him.
NathanOlder wrote: ↑27 Oct 2020, 23:32
I guess the short wheelbase and high rake not going to help. But I am not sure whether this is the issue with Albon, since the TR is basically the same platform.Big Tea wrote: ↑27 Oct 2020, 22:45Is anyone able to shed some light on why the car id that twitchy and why it can not be altered on just the one car?nevill3 wrote: ↑27 Oct 2020, 22:23From what I have seen of Albons performances recently I believe that RedBull regularly try non optimal contra strategies with him. This is partly due to his qualifying results I think which then get compounded by RedBull bringing him early or trying something different with his tyres to attempt an upset or at least rule out things for Max to try.
If Albon could qualify directly behind Max we would get a more representative performance. Last week Alex was able to keep up with Max once he had been lapped by him so his speed in the race is not in question I am sure. His main problem is qualifying, but trying to push to the limit in a car that is as delicately balanced as the RedBull is this year has often seen him try a little too hard and results in a disappointing qualifying result from which his race becomes a battle to gain the lost ground and results in RedBulls experimentation with differing strategies which are sub optimal. Christian knows they do this which is why he has supported Alex so much. With the RedBull car getting more stable and less prone to snap Alex's excuses are diminishing which I think has prompted the change in Christian's messages to the press.
Or do they want both cars set up identical so they can use the feedback from Albons tyres?
They are obviously not going to alter the car away from Max's preference, but why can they not 'tame' alex car?
Is there something fundamental that they can not trim out? Weight distribution if fixed (is it not?) so what is left that can not be tuned out? It is not like they were looking for grip on a bad car, just balance on one.
He seems to suffer more in qualli than in the race, so would it be tyre related? Also, I don't know red bull would find his feedback (well, by feed back I mean call him in to look at his tyres) much use for Max, which seems to be his job.Edax wrote: ↑27 Oct 2020, 23:56I guess the short wheelbase and high rake not going to help. But I am not sure whether this is the issue with Albon, since the TR is basically the same platform.Big Tea wrote: ↑27 Oct 2020, 22:45Is anyone able to shed some light on why the car id that twitchy and why it can not be altered on just the one car?nevill3 wrote: ↑27 Oct 2020, 22:23From what I have seen of Albons performances recently I believe that RedBull regularly try non optimal contra strategies with him. This is partly due to his qualifying results I think which then get compounded by RedBull bringing him early or trying something different with his tyres to attempt an upset or at least rule out things for Max to try.
One thing I can think of is that the top cars seem to run the tires much closer to the edge. In the midfield you can see people fighting for the entire race and still have tires at the end. Try to follow someone for 3 laps in a RB, Ferrari, or Merc, or push too hard on an outlap and you will be counting blisters. In order to unlock the performance of these cars tire management skills count more than racing skills. Albon has shown that he can race, but I am not so sure whether he can make the tires work for him.
I see why RedBull want to try an outside driver now.Big Tea wrote: ↑27 Oct 2020, 16:02I don't think Gasly's performance is being downplayed, just his ability to drive THAT Red Bull car.Schuttelberg wrote: ↑27 Oct 2020, 15:10If I were Gasly, I'd sign the first offer I get for any team's junior academy let alone a drive for the first team. Not a fan of the way his performance is being downplayed. I've been a big supporter of Alex and I believe even now that he can really give Max a run for his money but that doesn't mean Gasly's performances should in any way be belittled.
The same for Albon. I think most people see them as promising drivers, but out of their depth in the RBR boss team.
I have been cheering Albon on since he moved to Red Bull, but I now think that if he stays there it will ruin him as a driver and his rep with other teams. He needs to go somewhere he ca show he IS good, and I thing AT would be ideal
Add to that that an outsider perspective on ways of working can also help a lot, and there's all the more reason to look outside their own academy for once. RB academy drivers have only seen the way AT and RB are operating, limits the odds that they come with good insights on how things can be done better around the team. Hulk & Perez have loads of experience with how other teams handle certain aspects, be it technical or operational.PlatinumZealot wrote: ↑28 Oct 2020, 02:30I see why RedBull want to try an outside driver now.Big Tea wrote: ↑27 Oct 2020, 16:02I don't think Gasly's performance is being downplayed, just his ability to drive THAT Red Bull car.Schuttelberg wrote: ↑27 Oct 2020, 15:10If I were Gasly, I'd sign the first offer I get for any team's junior academy let alone a drive for the first team. Not a fan of the way his performance is being downplayed. I've been a big supporter of Alex and I believe even now that he can really give Max a run for his money but that doesn't mean Gasly's performances should in any way be belittled.
A young driver that grew up in the RedBull system and then finally reaching the highest level in the top team likely creates an implosive level of pressure to perform, especially against the benchmark set by Max.
One could guess an outside driver has no such "Twist-ian" sentiments. Having no childhood in the RedBull workhouse, that driver simply enters the team with no emotions towards the ring leaders in Helmut, Christian and Dietrich. That driver only sees the steering wheel and the pedals, the lights the track and the flag.
I agree with such an experiment. And Perez is perfect for the job.
Gasly has been confirmed at AT for 2021 it seems, so he has time to plan an exit strategy. He could replace Ocon, were Ocon to dissapoint (I personally find Gasly more likable for sure, but that probably plays little role). Or, who knows what Haas & AlfaRomeo are up to in 2022. Kimi has to retire at some point, and by 2022 Pierre could be regarded as an experienced driver.raymondu999 wrote: ↑28 Oct 2020, 12:13So.... there was at one point some noise about Gasly looking at Renault as an exit strategy, given RB may potentially hurt his career. Thoughts? Gasly-Alonso perhaps?
DChemTech wrote: ↑28 Oct 2020, 12:52Yeah the announcement came out exactly 28 mins after my previous post ahahahharaymondu999 wrote: ↑28 Oct 2020, 12:13So.... there was at one point some noise about Gasly looking at Renault as an exit strategy, given RB may potentially hurt his career. Thoughts? Gasly-Alonso perhaps?
Depends on whether the contract he signs is before the new rules are passed or not. In any case these caps are extremely easy to get around. All that is needed is some creative accounting. Mercedes pay Hamilton 20 million and their 4 biggest sponsors have image rights and personal sponsorship deals with him totalling 20 million: problem solved. That can never be regulated and has no basis for regulation in any court in a free market system.
Yeah that's true, sponsor deals are excluded. And then it only starts 2023 anyway, so drivers still have some time to figure out their strategy.tangodjango wrote: ↑28 Oct 2020, 13:02Depends on whether the contract he signs is before the new rules are passed or not. In any case these caps are extremely easy to get around. All that is needed is some creative accounting. Mercedes pay Hamilton 20 million and their 4 biggest sponsors have image rights and personal sponsorship deals with him totalling 20 million: problem solved. That can never be regulated and has no basis for regulation in any court in a free market system.
