Different level.
Different level.
(small correction: one can dislike *dominance* of this magnitude, independent of the team doing it)El Scorchio wrote: ↑01 Nov 2020, 15:38Well it depends doesn’t it. Objectively and statistically it is the best. If you don’t like them, then it is indeed the worst.
Fair play!nzjrs wrote: ↑01 Nov 2020, 15:42(small correction: if one doesn't like *dominance* of this magnitude, independent of the team doing it)El Scorchio wrote: ↑01 Nov 2020, 15:38Well it depends doesn’t it. Objectively and statistically it is the best. If you don’t like them, then it is indeed the worst.
I disliked it when ferarri did it, and when RB did it (to a lesser extent, the Alonso seasons were close), and I dislike it when Merc does it.
But yes if course it is the the best in history, I can math.
In fairness to Bottas, he did have damage and his fastest lap was only half a second off Hamilton's. So not bad in the circumstances.
Very true. Did a tidy race and kept it out of the wall and away from other cars. If you want to praise Russell for the prospect of top ten then you have to give Latifi credit for a good clean race and a good finish. If only HIS dad were rich enough to own a team too
He pulled out a big lead after the debris was removed though.Just_a_fan wrote: ↑01 Nov 2020, 15:47In fairness to Bottas, he did have damage and his fastest lap was only half a second off Hamilton's. So not bad in the circumstances.
