This would be true if you raise the 2008 wing to the same height as the 2009 wing. But with the lower position of the 2008 wing, it sits in a lot "dirtier" air, which makes it a lot less effective. I believe (I could be wrong) that the more narrow 2009 wing in it's higher position, is just as effective as the 2008 wing in it's lower position.kilcoo316 wrote:Anyway, the 2008 wing will have much better L/D figures than a 2009 wing - simply because it has a wider wing span. They can try to match 2008-2009 downforce figures, they can try to match 2008-2009 drag figures - but they simply cannot match both at the same time. Anyone that thinks otherwise could do with brushing up on the equations pertaining to lift dependent drag.
The reason that the rear wing was raised for 2009 was to make it easier for the cars following closely behind (the "hole" produced by the rear wing was moved up and away from the front wing of the following car), and the reason it was made more narrow was that it would otherwise have been far more effective in it's new position. (The reason for the high and narrow 2009 wing was NOT to reduce the overall downforce, this was made by changes to the diffuser and by getting rid of the extra wings, fins and chimneys that used to clatter the bodywork.)
