Why were Group C prototypes so much slower than F1 cars?
Potto
Potto
Since the European and Japanese Group C and American IMSA prototypes developed so much more downforce than F1 cars I would think that they could at least put down laptimes that were close. It seems that even the fastest race lap in F1 is several seconds quicker than the fastest World Sportscar Championship qualifying lap, even on the circuits where top speed and downforce matter the most. Maybe I'm just missing something but I'm really confused as to why even the later Group C racers with the new regulations that weighed very little and had the most downforce can't get close to Formula 1 laptimes.
jjn9128
778
Re: Why were Group C prototypes so much slower than F1 cars?
Comparing Group C to what era of F1? The latter Group C cars probably generated similar downforce to the current spec of F1 but with better efficiency because of the closed cockpits and wheels. Then you have power, power delivery/driveability (no drive-by-wire and throttle maps), and plenty of good ol' fashioned turbo lag. They weighed more than F1 - especially considering driver weight wasn't included. 5 speed manual gearboxes rather than seamless shift 7/8 speed. No other driver aids like programmable differentials. Then there's the fact endurance cars used to have to be coaxed around an event - these days LMPH is more of a sprint than F1.
#aerogandalf
Maritimer
Maritimer
19
Late era GroupC/GTP cars were faster than CART at the tracks they both ran, but I'd wager they lacked the drivability of F1 cars due to the turbo tech back then. Weight is also a big factor when you're at the point end like these series are, considering modern LMP1 also make/made more downforce than F1 cars but are still slower around Silverstone or Spa.
The XJR-14 was as a fast as an F1 car - it would have qualified for the British GP in 91, and not at the back but near the front.
But then the XJR-14 was an F1 car with covered wheels so it was no surprise. Taking 150kg out of the car's minimum weight was the key, of course. Before then, Group C cars had been too heavy to be able to set F1 lap times, even with the downforce they had. The XJR-14 was still heavier than F1 cars of the day but would have been able to keep up.
Smokes
Smokes
Bernie wasn't happy that group C cars were as fast as an F1 car so he got fia to make them heavier
Potto
Potto
Just_a_fan wrote:
28 Nov 2020, 02:33
Are you sure about that? On Wikipedia it says that the XJR-14 did a 1:27.478 around Silverstone which would've put it 29th on the F1 starting grid. That's certainly very quick but it's far from the F1 cars.
