You could see Checo’s move coming from a mile away, hell I’ve done it. I’m not convinced Leclerc was even going to make the corner.
You usually dive for the apex not expecting someone to be straight lining it up the inside. The braking zones are so short on these F1 cars, that you really can’t see it coming.1s (or 2s, literally) they are way back there, then they are into you.
As pointed out earlier, this is his second incident in the same fashion, third if you count an almost miss. Could you imagine this place if Grosjean did this? His youth can be written off, these guys have hundreds of races under their belt by the time they get to F1. They know how this works
