If there is no tehnical rules what is best theoretical design of underside for get maximum downforce for given car?
here is some solutions:
I think i have that somewhere...
I dont know how to desing entry part,flat(left 1 picture) or lifted up(left 2 picture),and how long narrow section must be?
Well I’m no expert but I’d say the second on the left or top right comb would be the closet diagram of a Venturi tunnel
I dont know work with CFD.Greg Locock wrote: ↑18 Dec 2020, 23:18you could run experiments in microcfd http://microcfd.com/2d.htm to find out whether the traditional venturi shape is optimal, and how much it is affected by the nose and upper body.
I believe the trick they found was increasing the mass airflow helped most.Just_a_fan wrote: ↑19 Dec 2020, 01:45Be worth looking at history too. The sports car prototypes often struggled to get the expected performance with growing diffuser size. Took them a while to figure out how to get it all working. Bigger doesn't automatically mean better.
Ross Brawn and John Piper who designed the xjr14 came up with a very clever idea on how to seal the floor. They put a flap between the front and rear tyres. This can be traced to the new f1 cars on sealing the floor. Same idea...Zynerji wrote: ↑19 Dec 2020, 07:14I believe the trick they found was increasing the mass airflow helped most.Just_a_fan wrote: ↑19 Dec 2020, 01:45Be worth looking at history too. The sports car prototypes often struggled to get the expected performance with growing diffuser size. Took them a while to figure out how to get it all working. Bigger doesn't automatically mean better.
Uwe wrote: ↑18 Dec 2020, 14:15If there is no tehnical rules what is best theoretical design of underside for get maximum downforce for given car?
https://images.pexels.com/photos/622541 ... =650&w=940
You need to think in three dimensions and (almost) treat the front of the car as a separate entity to the rear (but not at the expense of the rear!).
The position and shape/size of the ‘throat’ will determine the sensitivity of the downforce generated and the CoP location.
The design of the inlet will determine the potential of the system, and the outlet the efficiency of the system.
Stu wrote: ↑19 Dec 2020, 10:46
