I was thinking that if fuel was available, the 'easy way' to get power is add cc, add boost, add revs.Just_a_fan wrote: ↑19 Jan 2021, 20:47I don't know. Is a fuel flow rate a better restriction or is just a total fuel amount as good/better?Big Tea wrote: ↑19 Jan 2021, 20:16Would it not be better to just state the maximum flow rate if you want to open up options?Just_a_fan wrote: ↑19 Jan 2021, 17:58It would be an interesting process to watch if the FIA just said "you have 100 litres of fuel(*) to do the race, go and build your PU to make the best use of it. Car has to meet the usual other requirements for safety and aero limits. What have you got?"
(*)If the fuel allowance is below a certain critical value, some form of hybrid systems will be required to be competitive. The question is what is the critical fuel amount that forces the engineers to do more than just ask the drivers to lift and coast? Storing some of the wasted energy will be required in order to be competitive.
This would mean for power to be used alongside the ICE when at maximum requirement, and stored when there is spare capacity?
All the traditional way to do things that have been covered this last decade.
With a flow limit, none of the above would be worth much investment as its old hat.
The only 'easy' ways to send makers down a different path is to give a restriction or an 'unexploited avenue'
If if total fuel is restricted it would make them chase economy and efficiency, but they have been doing that since the fuel allocation was first introduced, and it must be costing more and more to gain less and less by now, so a chance to go in another direction will leave the low hanging fruit while research comes through.
This is of course as well as any regen that could be allowed, but that is almost a cert now though.
Just my personal thinking, not that I am that good at thinking.
