I don't, the air resistance is very important. The acceleration of a gravity racer is basically determined by its ratio of mass to air resistance. If you can keep the air resistance the same and increase the mass, the acceleration will increase.
At the limit case, where the mass is huge and the air resistance negligible, the racer will accelerate at 1G times the sine (I think?) of the slope angle, and increases in speed will not result in any significant reduction in the acceleration, because the ratio of the air resistance to the mass will be very small.
A practical example would be the difference between a leaf and a ball bearing.
