They are completely different monococques - with completely different lay-ups which define completely different torsional properties.
To proof that to this comunity kilcoo will have to post the plybooks or anything similar of both monocoques so that we all can compare.
I do not expect that to happen for obvious reasons even if kilcoo has access to such documents.
To recap, if someone thinks that these cars share the same chassis, they are the ones who should be providing proof.
I agree with you. Nevertheless i want to give some basis for arguing pro/con this "same chassis theory". Not having another opportunity (except believing kilcoo - what i do not consider the worst
) we got stucked to picture analysis.
Therefor i like to post two pictures which show both cars from nearly the same angle and compare some points. I am aware that Conceptual may call me another photograph surveyor but this is what in my opinion most of this board is about. Unfortunately Force Indias white on white doesnt help much for the cockpit area but i simply failed to found a better pic.
Comparing both pictures the following catched my eye:
-The rockers have different position. Not only that the rocker axis on the FI is neraly parallel to the ground - the attachment point is more in front than at the McL. Only for this reason the tubs cant be the same while the rocker applies the biggest force to the monocoque.
-Follow the upper profile of both tubs from the cockpit opening on to the front. While the McL is horizontal and slightly falling down from the rocker attachment onwards the profile of the FI heads slightly upwards and discibing a big radius until the nose.
-The keels between splitter and monocoque which i consider as part of the tub are completely different.
-the difference in height between the upper rim of the cockpit sidewall and the head restraint is completely different. unfortunatly you cannot see it on these pictures due to the white on white.
I hope my post helps to return to what we can judge on. Just want this thread to be less sarcastic and get back closer to the original topic.
