JordanMugen wrote: ↑11 Feb 2021, 15:37
I feel the V12 would deliver a far superior entertainment spectacle for Formula One and would be the preferred solution of many fans. It would serve to eliminate the inessential turbocharger and MGUH from the powertrain (in exchange for 6 extra cylinders and injectors), while the power units could still be developed under a maximum fuel flow regulation for optimal
naturally aspirated efficiency -- which would alleviate concerns of manufacturers merely "throwing bulk fuel" at the power unit to make power, which would be seen as environmentally untenable.
How so? How would racing be better with dodo engines? The main results would be less reliability (probably), and much worse efficiency (for a certainty). V12-s especially, they died out on their own, because it they were inferior to V10s.
Nothing useful to be gained. And only a small minority (even if it's a loud one) ejaculate in their pants from their sound, with no regard for the quality of racing or the intrigue of cutting edge technology.
Ringleheim wrote: ↑11 Feb 2021, 20:08
I love that environmental and social relevance concerns are NUMBER ONE.
Hello, the socially relevant and environmentally sound approach to F1 is to abolish it!
LOL
Build normally aspirated screamers and let the fans enjoy the racing again.
None of this stuff is "socially relevant".
If they want to be relevant, make hydrogen powered engines. That's where everything will be down the road anyway.
You're using strawman arguments. There are few things that society cares more than entertainment, which includes F1.
Who only (or chiefly) care for dumb noise or not F1 fans only noise-nuts.
And your hydrogen comment was discredited by Jolle. But you're even more wrong than that implies, because you said "engines" insead of "motors". Burning hydrogen in engines is outright foolish. You'd just waste more energy with something that's also inferior by every measure of performance as well.
