coaster wrote: ↑27 Feb 2021, 05:49
Fuel tank putty works also, I smoothed the inside of a 2 barrel stromberg and removed its choke, added a homemade nylon 25mm open chamber carb spacer on a worn out V8. The cam timing was already retarded a good amount by way of a stretched timing chain which i did not touch. None of my car buddies could believe how hard that motor went, i kept secrets like a 6mm taller air filter which bypassed the snorkel, ball bearing in the vacuum line for vacuum advance delete, bigger fuel filter and fittings, drilled the originals which could not be upsized.
That was in 1997, a 1979 VB Holden Commodore which was basically a German Opel Senator with an American iron V8 jammed in, from factory!
I hate that I grew up in an auto industry city because in doing so I was obsessed by cars, still am to my detriment. My career scope had a narrow focus to this which i now regret in middle age.
I should have switched on that Sinclair computer more often and learnt something other than spanner work.
Hey wait on, that VB Commode was reinforced locally to handle the 'rough as guts' local
roads & not fall apart too quickly, compared to the 'Detroit' mandated Kingswood/Torana
which it was replacing, & that "American iron V8" - was also much lighter (& better sounding
with more grunt) than the actual 'Detroit' 5 litre GM V8's of the era - to be fair, wasn't it?
