2026 Hybrid Powerunits
Big Tea wrote:
07 Mar 2021, 12:45
A L3 cyl is also 'half' a current engine size, and less cooling requirement. Would it be ridiculously inefficient to make it aircooled?
Thinking of all the saved radiator space
Isn't the issue with air cooling that it's not good enough in high performance car engines? The beauty of a radiator is that it can easily have massively greater surface area for heat transfer than any air cooled engine could achieve, also adding a larger radiator is easy compared to making the air cooled fins larger/more numerous.
Obviously Porsche have done quite well over the years with air cooled engines, but not in a compact installation like in F1 and not without a fan.
Holm86
261
V4 is better as a stressed member than L4 or L3.
And how are they supposed to increase the BTE from 50% to 60%?? 50% is pretty impressive as is.
And if they go with some sort of bio fuel, they need to up the fuel flow, as many biofuels doesn't have the same calorific value.
Holm86 wrote:
08 Mar 2021, 11:54
Could one run a three cylinder engine in a T shape? Inverted so the cross bar part was at the bottom, you'd have a good shape to use as a stressed member and a low crank height. I assume the vibration / harmonics (whatever the term is) would be horrible, but it would be very short and could be made very stiff. If one wanted to air cool it (as suggested by someone in the thread), that would also be easy as no cylinders get in the way of air flow of other cylinders.
But I know very little about engines and their design/implementation. :lol:
Holm86
261
Just_a_fan wrote:
08 Mar 2021, 12:12
Holm86 wrote:
08 Mar 2021, 11:54
You mean something like this??
Holm86 wrote:
08 Mar 2021, 12:43
Just_a_fan wrote:
08 Mar 2021, 12:12
Holm86 wrote:
08 Mar 2021, 11:54
https://upload.wikimedia.org/wikipedia/ ... _angle.gif
Yes, something like that. =D>
senja
senja
That's more like W shape. :D
Big Tea
Holm86 wrote:
08 Mar 2021, 12:43
Just_a_fan wrote:
08 Mar 2021, 12:12
Holm86 wrote:
08 Mar 2021, 11:54
mount it like this?
https://www.motortrend.com/uploads/site ... -view2.jpg
mzso
mzso
75
Just_a_fan wrote:
08 Mar 2021, 12:12
Holm86 wrote:
08 Mar 2021, 11:54
Why not boxer 2 then? :)
Stu
Why the resistance to using an inline engine (either 3 or 4 cylinder), if it was a part of the rules they would have to come up with something to tackle the installation stiffness. The rules are full of restrictions that force the designers to come up with solutions to non-ideal regulations.
mzso
mzso
75
gruntguru wrote:
07 Mar 2021, 02:09
Under current rules there is 100 kg of fuel and we can assume the heating value is about 45 MJ/kg so there is a maximum of about 4500 MJ of energy available. If we assume a conversion efficiency of 50% and a race duration of 2 hours, the average engine output is 312 kW.
That's not too bad. Though the races are more typically 1.5 hours long.
Holm86
261
Stu wrote:
08 Mar 2021, 20:47
Of course they can come up with solutions to make it work, but why insist on an inline engine, when you can have the same number of cylinders in a V and keep the structural integrity??
If they have to find solutions to make the inline engine strong enough, it'll be heavier, and if there's something we don't want, it's heavier cars. They're already way too fat ...
Rodak
Rodak
37
Stu wrote:
08 Mar 2021, 20:47
The BMW turbo engine needed a supporting structure to carry the suspension loads as the inline four block couldn't do it; of course, they were using a production block. Still, an inline four would be way less stiff than a V6. Maybe F1 should go really retro and require a 9 cylinder air cooled radial....
Stu
...or a two cylinder rotary....
They already seem to be using external bracing on the V6 engines.
mzso
mzso
75
Stu wrote:
09 Mar 2021, 09:23
Did anyone ever build an efficient rotary engine?
Edit: We might not have been thinking of the same thing.
Stu
No, we are thinking of the same thing!
Until they started designing for the 2014 engine regs there was no heed paid to the efficiency (TE) of F1 engines, therefore to build an efficient rotary would be a challenge for the builders!!
What needs to be borne in mind with any upcoming engine regs is that if they want it to be road-relevant they need to push the regs in a direction that leads to the ICE being a part of an electrical generator unit.
