Did anyone post this picture (yeah tweet, but with interpretation of picture) yet?
The wastegate pipe causes its own bulge in the engine cover. Maybe it was done like this to minimize that needed bulge?C Plinius Secundus wrote: ↑10 Mar 2021, 16:26I think that internal packaging might be a more probable reason, thinner pipe, less bulk
Yes, it could be another reason. They have (apparently) changed the turbo, for some reason they didn't (or couldn't) remove the wastegape pipe altogether, so perhaps they use a smaller section pipe to pack it more tightly... every milimeter counts...Zynerji wrote: ↑10 Mar 2021, 16:28The wastegate pipe causes its own bulge in the engine cover. Maybe it was done like this to minimize that needed bulge?C Plinius Secundus wrote: ↑10 Mar 2021, 16:26I think that internal packaging might be a more probable reason, thinner pipe, less bulk
The wastegate pipe exit isn't the only thing prescribed, they also are required to have a wastegate, which indeed means they cannot get rid of the piping eitherC Plinius Secundus wrote: ↑10 Mar 2021, 16:42Yes, it could be another reason. They have (apparently) changed the turbo, for some reason they didn't (or couldn't) remove the wastegape pipe altogether, so perhaps they use a smaller section pipe to pack it more tightly... every milimeter counts...Zynerji wrote: ↑10 Mar 2021, 16:28The wastegate pipe causes its own bulge in the engine cover. Maybe it was done like this to minimize that needed bulge?C Plinius Secundus wrote: ↑10 Mar 2021, 16:26
There is " " around "abondeoning".wowgr8 wrote: ↑10 Mar 2021, 15:22Abandoning their design what do you mean? Since 2017 they've just evolved the lower SIPS design further and further. 2019 to 2020 there was the change where they got rid of the intake on the top side of the sidepod but what you see today is just ultra tight engine cover/sidepods with that Red Bull style crease, it's a natural evolution IMO, most of the grid following that Mercedes sloping sidepod thing they did with the W10Blackout wrote: ↑10 Mar 2021, 14:41It's weird to see Ferrari, the inventor of this type of sidepod intakes in 2017, 'abandoning' their typical design to copy that of other teams....
The sidepod bodywork is completely different too and it adopts the redbulian downwashy style.
Complete break with what they've been doing since... phew
But they retained a Ferrari style.Since 2017 they've just evolved the lower SIPS design further and further
it's all the things together... less weight = smaller part = less bulky = more space for other stuff = less heat...C Plinius Secundus wrote: ↑10 Mar 2021, 16:42Yes, it could be another reason. They have (apparently) changed the turbo, for some reason they didn't (or couldn't) remove the wastegape pipe altogether, so perhaps they use a smaller section pipe to pack it more tightly... every milimeter counts...Zynerji wrote: ↑10 Mar 2021, 16:28The wastegate pipe causes its own bulge in the engine cover. Maybe it was done like this to minimize that needed bulge?C Plinius Secundus wrote: ↑10 Mar 2021, 16:26
Interesting, but, hasn't Mercedes gone "sans pipe" on their W12 for example? I'm a little confused...bosyber wrote: ↑10 Mar 2021, 16:44The wastegate pipe exit isn't the only thing prescribed, they also are required to have a wastegate, which indeed means they cannot get rid of the piping eitherC Plinius Secundus wrote: ↑10 Mar 2021, 16:42Yes, it could be another reason. They have (apparently) changed the turbo, for some reason they didn't (or couldn't) remove the wastegape pipe altogether, so perhaps they use a smaller section pipe to pack it more tightly... every milimeter counts...
Nicolas Carpentiers wrote:Apart from the different geometry (front element of the top wishbone seems to attach further forward to gearbox), there is something new in this area, see yellow. Not sure what is it. Aero device (it was part of the bodywork in 2020) or mechanical one (but what)?
