Mercedes W12
Xwang
Xwang
29
Re: Mercedes W12
El Scorchio wrote:
26 Mar 2021, 16:46
Have they used their tokens on increasing the rake/raising the back of the car? (Assuming that requires token spend.)
That would be something that's obvious and clear.
Maybe they have changed suspension internals to be able to use more rake?
dans79
267
Re: Mercedes W12
Xwang wrote:
26 Mar 2021, 16:49
El Scorchio wrote:
26 Mar 2021, 16:46
Poissible, but I would think they would want to change the gearbox mounting points more.
If it is the suspension internals, then it will probably be a easier fix, as all they need to do is learn how to dial in the stiffness etc.
201 105 104 9 9 7
cheeRS
cheeRS
Re: Mercedes W12
Xwang wrote:
26 Mar 2021, 16:49
El Scorchio wrote:
26 Mar 2021, 16:46
During FP1 today the commentators (can't remember if it was Jensen or Karun) mentioned that the Mercs had higher rake than before, so...maybe? I think Christian Horner mentioned it, too.
Perhaps most curiously (and significantly) Toto Wolff said: ""You haven't seen what we intend to install on the car," Wolff told Canal Plus. "Thankfully there is still room for innovation, which always makes me happy.
"Every day we are trying to do something a little different. I'm not sure if it will make a big difference in the speed of the car, but it will be good if it works."
Human history is the long terrible story of man trying to find something other than God which will make him happy.
kfrantzios
kfrantzios
46
Re: Mercedes W12
From FP2 right at the apex. It seems more rake to me
nico5
21
Re: Mercedes W12
kfrantzios wrote:
26 Mar 2021, 19:40
https://i.imgur.com/agkttiw.jpg
No I'd say that's the same angle they used for the past three years. Be mindful, it's mid-corner and it's a slow one so there's naturally more rake than, say, through turn 3 at Barcelona. But it's nowhere near that of a rakey car.
Fulvio2044
Fulvio2044
Re: Mercedes W12
#3DModeler - Tech Passion for F1 - Cycling and all Sport #Cyclist.
Technical writing for https://www.salastamparacing.com/
jagunx51
185
Re: Mercedes W12
Just_a_fan wrote:
26 Mar 2021, 14:57
jagunx51 wrote:
26 Mar 2021, 14:50
Just_a_fan wrote:
26 Mar 2021, 12:13
Oh, yes I see it now. D'oh! :oops: :lol:
https://pbs.twimg.com/media/ExUc-tOWYAc ... ame=medium
Did you mean to post that somewhere else? :wink:
just want to show what might be the lump on engine cover seen on Merc & AM cars
eppholdoor
eppholdoor
Re: Mercedes W12
Fulvio2044 wrote:
27 Mar 2021, 01:22
That looks very misleading. If you look at where the bottom line ends in relation to the rear wheel you'll see it's lower in the top image than in the bottom image, making it look like the angle is bigger than it actually is.
cheeRS
cheeRS
Re: Mercedes W12
jagunx51 wrote:
27 Mar 2021, 01:35
Just_a_fan wrote:
26 Mar 2021, 14:57
It's been confirmed already. Plenum bulge. Sexy.
zibby43
zibby43
613
Re: Mercedes W12
MKlaus
MKlaus
Re: Mercedes W12
the difference of a few millimeters in rake is impossible to take on the face value when cars are under different loads at various intervals and at a slightly different photo angles, even at the same spot. it would be a futile exercise, unless team confirms at some point that they indeed have changed the ride heights.
OO7
OO7
171
Re: Mercedes W12
Fulvio2044 wrote:
27 Mar 2021, 01:22
There's a significant difference in the speed of the cars.
LM10
LM10
121
Re: Mercedes W12
To me on live footage it was pretty clear that the Mercedes has more rake now. No matter if high speed or low speed.
Tizz
Re: Mercedes W12
I think I heard one driver say in FP2 that the car was undrivable. I think it was Bottas. Is that correct ?
w1Y
w1Y
Re: Mercedes W12
I think they may be playing around with rake because some parts of practice they looked the normal self close to the ground and other times higher.
I assume they want to use high rake but maybe struggling to get a balance.
