2021 Mclaren F1 Team
Seerix
Seerix
Re: 2021 Mclaren F1 Team
Seerix wrote:
18 Apr 2021, 14:50
Oh man, does everyone have tents on grid except for one Mclaren car? I hope that won't affect our start too much..
Nevermind, most of the teams removed those tents already, so no real difference in dry/wet gridspot.
Fingers crossed.
Darth-Piekus
-1
Ok not a good start so far. Norris lost places but Ricciardo gained a place.
101FlyingDutchman
101FlyingDutchman
At least they’re out of the wall/incidents. Not ideal for NOR but we can fight from here.
Emag
Emag
113
Did Norris pick up any damage? I saw in the team stream that they asked him to drive past the pitlane so they could check the bargeboards, but there's no more information since then.
Developer of F1InsightsHub
Darth-Piekus
-1
Let's hope not something that will keep him from fighting to gain places.
SmallSoldier
SmallSoldier
486
diffuser wrote:
SmallSoldier wrote:
17 Apr 2021, 01:01
Hammerfist wrote: Merc deployment still class of the field? Thats not the latest i heard. They were clipping like crazy in bahrain and the honda deployment was reportedly better over there. At the end of the day does the merc pu help aston martin and williams compared to their competitors? I sure as hell cant see it. I think too many people dont realize that engine convergence is pretty much here and the pu is not as important as it was say 2-3 years ago.
Minimizing the impact of the PU due to AM/RP or Williams performance it’s not a good argument (because in that case, the performance of AT, Haas, AR are bases for the same argument for the other PU’s).
I don’t think there isn’t much or any doubt that Mercedes still makes the best PU in the grid, this is acknowledged by every team in the grid (and every engine manufacturer).
There is no doubt that it is superior to the Renault PU, not only in terms of Power and Reliability, but also in terms of packaging (and this has been confirmed by Mclaren)... In a sport like F1 where millions are spent for small increments in performance, using the best PU if possible is the best course of action.
In regards to deployment, yes, the Mercedes PU had derating issues in Bahrain, but it wasn’t “massive” clipping as you state and most probably will be solved through software calibration more than hardware fixes.
Packaging isn't part of the PU. The different PU architectures will give you different packaging options. When RBR take the exhaust and roll them up in a way that they fit under the PU and not on the side... that's RBR Packaging of the exhaust with the requirements from Honda. If Williams, for example,where to get the Honda PU, they don't get the RBR exhaust. You don't get any Radiators with the PU. That's all on the purchaser to create.
Cooling requirements determine the size of your packaging... The Merc PU runs hotter and if I’m not wrong smaller radiators... The change in turbine layout also plays a role in how you “package” it under the covers... It has allowed McLaren for an slimmer body overall
Lucky
Lucky
157
Lando =D>
101FlyingDutchman
101FlyingDutchman
We needed that!!
Darth-Piekus
-1
Bravo Lando. That is what you need from a top driver. Now to chase Leclerc as at the moment he is trashing Perez.
Emag
Emag
113
Lando clearly the faster driver, I think they should tell Ricci to let him through.
MrGapes
34
Lando chasing ricc
101FlyingDutchman
101FlyingDutchman
Defo what they should do. Best for the team
Darth-Piekus
-1
Its gonna be hard for Norris to catch Leclerc. He has gained a significant advantage.
MrGapes
34
Dany needs to let Lando through
SmallSoldier
SmallSoldier
486
Lando is super racy!!! The team needs to let him through, he has pace to catch Perez!
