I think too much is being made of this. It’s clear that drive out of the last corner was the biggest factor. Mercedes were just better at that key point of the track and it made for an exaggerated looking pace differential on the straight. The Red Bull was definitely faster through the middle part of the lap, but you can’t overtake there, and then all the ground made up was lost on the last corner.Jaisonas wrote: ↑03 May 2021, 13:51Thats the reason i speculated clipping or deployment in general. The poor race trim, cause it doesnt make sense having such a great power on quali trim and falling that much behind in race trim considering they use the same engine mode between those. Remember that only deployment changes between race and quali now.Juzh wrote: ↑03 May 2021, 13:45Yes, clipping is not a problem, outright power is and that's even worse. Mercedes owns honda in race trim for whatever reason and has been since start of the season (sitting duck comment anyone?). It's basically impossible to overtake a mercedes in a regular overtake, whereas mercedes will easily destroy you if you give them but a sniff of opportunity.
It was all about being the quickest car round the last corner in the race rather than fastest over the whole lap.
