As far as I can tell the load tests in 3.9 are defined for front and rear wings and the floor, but I can’t see anything for engine covers other than a general requirement in 3.8b to be rigid.
For flexing wings the rules don't need to be changed, as a catch all rule that covers this specific scenario, already exists.
In order to ensure that the requirements of Article 3.8 are respected, the FIA reserves the right to introduce further load/deflection tests on any part of the bodywork which appears to be (or is suspected of), moving whilst the car is in motion.
With the exception of the parts described in Articles 11.4, 11.5 and 11.6, and the rear view mirrors described in Article 14.3, any specific part of the car influencing its aerodynamic performance: a. Must comply with the rules relating to bodywork. b. Must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom). With the exception of the driver adjustable bodywork described in Article 3.6.8 (in addition to minimal parts solely associated with its actuation) and the parts described in Articles 11.4, 11.5 and 11.6, any specific part of the car influencing its aerodynamic performance must remain immobile in relation to the sprung part of the car. Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances. No part having an aerodynamic influence and no part of the bodywork, with the exception of the parts referred to in Articles 3.7.11, 3.7.12 and 3.7.13, may under any circumstances be located below the reference plane. With the exception of the parts necessary for the adjustment described in Article 3.6.8, any car system, device or procedure which uses driver movement as a means of altering the aerodynamic characteristics of the car is prohibited.
However we know they engaged with the FIA at an early stage in the design process. Technical director James Allison recently explained how the team raised the DAS concept with the FIA a year ago.
In that early incarnation, DAS was operated not by sliding the steering wheel forwards and back as onboard cameras revealed in February and showed again in practice yesterday. Instead, as Allison, described a separate lever was originally used to achieve the adjustments in toe angle DAS allows.
“They begrudgingly agreed the dual axis steering was actually legal,” Allison recalled of their dealings with the FIA. “But they didn’t much like the way we’d done it because the second axis we were getting from a lever on the wheel rather than that whole wheel movement. They said ‘no, you’re going to have to move the whole wheel in and out’.
“I think when they said that, they were hoping that would be too difficult and that we would go and cause them no more problems.”
That didn’t happen. Mercedes built DAS using the ingeniously simple and satisfyingly lateral solution of sliding the steering wheel back and forth. And more trouble followed when Red Bull objected to it.
I keep mentioning this. In combination with T-wing flex it probably has the same/similar overall effect as the flexing/reduced AoA rear wing - reducing load and drag on the rear of the car when DRS is not in operation.RaceFan1 wrote: ↑14 May 2021, 19:12There's been talk of the flexing rear wing and body work swell aiding cars straight line speed but, how about excessive shark fin flex? Mercedes is too detail oriented to leave this very flexible shark fin on the car if it weren't providing an advantage. Can the amount of flex in this piece of bodywork be aiding the Mercs more than a flexing rear wing at speed?
I don’t think that the T-Wing helps with drag, it actually adds drag... If not, the teams would be using them in tracks where more top speed (less drag) is required... The T-Wing adds downforce at the expense of the additional drag.Stu wrote:I keep mentioning this. In combination with T-wing flex it probably has the same/similar overall effect as the flexing/reduced AoA rear wing - reducing load and drag on the rear of the car when DRS is not in operation.RaceFan1 wrote: ↑14 May 2021, 19:12There's been talk of the flexing rear wing and body work swell aiding cars straight line speed but, how about excessive shark fin flex? Mercedes is too detail oriented to leave this very flexible shark fin on the car if it weren't providing an advantage. Can the amount of flex in this piece of bodywork be aiding the Mercs more than a flexing rear wing at speed?
I’d like to see a comparison of the RB wing at the same speed as the video that is doing the rounds but with the DRS open.
If the flexing shark fin and T-wing were harmful/not beneficial it WOULD be engineered out. The Mercedes has the most flex in these items of any team.
Disagree with that assessment. The very presence of a t-wing in and of itself adds net drag - however, very little. The t-wing acts as additional downforce (which is why it usually only appears on medium and high-downforce circuits).Stu wrote: ↑14 May 2021, 19:32I keep mentioning this. In combination with T-wing flex it probably has the same/similar overall effect as the flexing/reduced AoA rear wing - reducing load and drag on the rear of the car when DRS is not in operation.RaceFan1 wrote: ↑14 May 2021, 19:12There's been talk of the flexing rear wing and body work swell aiding cars straight line speed but, how about excessive shark fin flex? Mercedes is too detail oriented to leave this very flexible shark fin on the car if it weren't providing an advantage. Can the amount of flex in this piece of bodywork be aiding the Mercs more than a flexing rear wing at speed?
He takes many ideas from here. For the rest of the world its OK i guess. But for F1 tech its pretty much giving us regurgitated food.zibby43 wrote: ↑13 May 2021, 08:30Nice technical piece from Matt Somerfield on RB's "flapping phenomenon"
https://au.motorsport.com/f1/news/flapp ... e/6507247/
Excerpts:
"The new rotational tests will prevent the wing from ‘steering’ around the centre plane, a trick that the FIA may be focusing on as being used to circumvent the symmetrical loading applied in the deflection tests.
This is a notable feature in the onboard footage from the rear facing T-camera of the Red Bull, for example.
Close examination of the moving images shows the top rear wing element ‘flapping’ laterally, moving side-to-side with the relative vibration of the endplates, which owing to their design also find themselves oscillating.
This could explain how the wing ‘bends’ rearwards under load, as the wing pivots around the central axis, with one side of the wing moving incrementally rearward before the other."
Also, the 3-race grace period may be irrelevant, as rival teams could choose to simply protest wings that they believe fall afoul of the rules.
"It will be interesting to see if the new load/deformation tests have an impact on the competitive order when we head to the long straights at Paul Ricard.
Any team making changes to its wings, to ensure they comply to the rules, will also need to juggle the potential consequences that could have on them hitting the budget cap limit.
There could also be intrigue beforehand though, because teams could yet decide to lodge protests against their rivals should they believe they’re using a rear wing assembly that contravenes the current regulations, even before the new tests come in to force."
It seems?
Red Bull had a similar degree of flexing at Austria in 2020 for sure.hollus wrote:Slightly off topic questions:
Was Red Bull's having this level of deflection in the last high downforce race of 2020? Does Alpha Tauri's rear wing have anything similar?
Or is it really a new development (the extreme degree of flexing) for Red Bull in 2021?
