I'm sorry that this post is off topic, but it's replying to a post that should be deleted or at least fact checked.godlameroso wrote: ↑18 May 2021, 06:22Great, not disputing that at all, I'm disputing if the wing is bending illegally, I want to make sure it is.dans79 wrote: ↑17 May 2021, 23:13You're drastically overthinking this.godlameroso wrote: ↑17 May 2021, 22:51What is the distance from the camera to the rear wing? Let's assume the car is roughly 5.4 meters, I don't know how long it is off the top of my head.
The rules say the camera is 800mm above the reference plane. Is the camera parallel to the ground or the reference plane?
I don't know anything about cameras, if anyone does and wants to share what they know, it would be helpful to the discussion.
This is the type of camera used
https://www.resolveoptics.com/207-000-6 ... zoom-lens/
Anyway, assuming the camera is roughly at the middle of the car, that gives us around 2.7 meters from the camera to the rear wing.
Let's say the ride height is 100mm at the rear and squats to 90mm at speed for a 10 mm drop. Meanwhile the front ride height is 36mm and squats to 32mm at speed. I'm being purposefully conservative, the ride height at the rear may be more, I doubt it's less. That's a 6mm drop, 2.7 meters away, how would that translate on this camera? Again I don't know anything about cameras so I'm asking in case someone knows. So how much would it look if the rear end moves down 6mm relative to the front on a 3x zoom camera with some amount of lens distortion? I don't know, hopefully the stricter tests shed more light on the truth. I eagerly await it for obvious reasons.
I want to be sure, instead of just pointing fingers, let's be more thorough with our investigation like a good scientist is supposed to do. Instead of simply saying "the wing bends illegally let's burn them at the stake", let's instead say "it sure looks like the wing is bending in a weird way, let's get more information to be sure, and try to eliminate bias". Apparently people get offended at such a suggestion, oh well.
everything on the car except the tires, and the suspension components are all "rigidly" connected. It doesn't matter if the front end squats, the rear end squats, or the car's airborne and perpendicular to the ground.
Everything on the car will remain in the same position within the cameras field of view. It's all moving together. If you see movement, it's because something is moving or flexing relative to the other components.
This entire conversation has gone pretty much like this.
The wing bends, we see it on video. Ok we all agree there right? I see it, you see it, we are all in agreement it's as clear as the sun. No complaints so far right?
Then we move on to the next step, is it illegal?
That is my question to all of you, maybe I'm overthinking it, maybe I'm not, but my thinking is irrelevant here, let's focus on the important part, is the wing bending illegally? That is after all the main crux here right? Why we are all rousing the rabble.
If we examine the video carefully the most obvious part of everything is that we have a Mercedes wing, and a Red Bull wing. The Mercedes wing CLEARLY looks like it bends and deforms less than the Red Bull wing. We agree here still correct? No argument from me here so far. I agree the Red Bull wing appears to bend more than the Mercedes wing. So far we are all in agreement and the world is a wonderful place.
Here is where we disagree, and please correct me if I got this wrong.
The Mercedes wing is the benchmark upon which all wing legalities shall be measured upon, for although ALL the wings bend due to aero load, the Mercedes wing is by default, the very definition of legality and thus, the ONLY way a wing should deform under load. By decree of the FIA and Mercedes' exemplary rear wing deformation, all other competitors must have the same or less wing deformation. So sayeth the Forum.
To me that sounds pretty crazy, and I would like a little more due process than rule by decree.
My question, which I admit is a complex one to answer, is, by how much is the Red Bull wing illegally deforming compared to the benchmark Mercedes rear wing which is without question in its legality? That's all, it's a straightforward question that is met with some interesting evidence.
It seems that other cars exhibit the same behavior as the Red Bull, in that we should also be in agreement. The Williams's rear wing deformation for example is in line with the benchmark of legality Mercedes, and thus they deserve no scrutiny. Haas? A backmarker, Toto tells them to get out of the way who cares what they're doing.
The other cars like the Alpine and Ferrari also exhibit this behavior, but we all know the Red Bull's wing is the most illegal because there was a video with white square grids which showed the wing moving a whole square but not a whole square on Mercedes. Again implying Mercedes deformation is perfectly legal and without question and the benchmark that all other cars must abide by.
I agree with you guys, the Red Bull wing is the most illegal because they are the biggest threat to Mercedes, that makes them the dirtiest cheaters, just like Ferrari and their cheating engine in 2019 when they started threatening Mercedes. I agree Red Bull's wing is the most illegal that's why the FIA is stepping in and forcing stricter tests, we don't want cheaters. I agree cheating is shameful, but that's my personal belief and has no place here.
Anyway, yes the Red Bull wing is illegal, and the video clearly shows it, and so the final question remains, by how much is it illegal? No one can answer that here, but we are sure it's illegal because when compared to the Mercedes wing it's doing something that the Mercedes wing doesn't seem to do. All factors have been accounted for so there is no way any optical illusions or bias are playing tricks on us, it's clearly illegal, and the video shows it.
So again, I ask the most pertinent question, the video shows the wing bending, so by how much more is the wing bending on the Red Bull than on the Mercedes? Can anyone quantify it, the difference between the two wings at speed and at rest? If I get mocked for 2mm how can I take 10 pixels seriously, when it's an even dumber metric for the wing's illegality? I'm sorry, but would any of you take me seriously if I told you 10 pixels were the difference in Verstappen nailing a corner vs Hamilton? I'm supposed to believe 10 pixels mean the difference between Red Bull and Mercedes illegality? Okie dokie.
The FIA wrote to all the teams, and new tests apply to everyone, not just Red Bull.
The stuff about "Mercedes benchmark" is ridiculous, it's the FIA that scrutinize cars to meet the current regulations.
http://www.formula1-dictionary.net/scrutineering.html
It was Red Bull that complained to the FIA about Ferrari!
https://www.autosport.com/f1/news/red-b ... 9/4986309/
Red Bull gets F1 fuel flow rule clarification amid Ferrari intrigue
The Red Bull Racing Formula 1 team has written to the FIA for clarification over a potential loophole it believes could be used to 'beat' the fuel flow regulations
