If you've ever wondered why most of the world switched to Metric, watch this video!
It's A/ Hilarious and /B equally educational - the research into this topic to make this video is quite impressive.
I remember having to time sheet things using decimal time. Everything ended up being recorded in 15 minute lumps because it's obviously dead easy to do then. Which made the time sheet process a bit pointless really.
We have about four different beer glass sizes in Australia, none of them are legally controlled afaik. Varies from state to state too.Just_a_fan wrote: ↑20 May 2021, 09:25Except for the pint in the pub. That must always be in pints. Always. "I'm going for a quick 568ml with the lads, love, see you later" doesn't work, does it?
Ours are advertised in both inches and centimetres. Inches is used generally but legally CM is the unit.
Now you mention it like that...
