Alonso wrote:Sdimm so what you saying is that to much castor would create a very nervous car because the front is to good? Would this create a snap oversteer threw fast corners such as high speed sweeps and exiting slow to medium corners power on. And also what you saying is that castor does not effect camber when turning in to corners because the degrees that you need to turn is not enough to effect it.
Thanks Alonso
Well the car would try to center the steering with to much force meaning that you loose the feel in the steering and it can´t help you to countersteer a drift. Sure, I suppose that if you have to steer into the corner with great force that could make the car more nervous if it starts to oversteer since you can react to if fast enough.
It´s not about good or bad but feel.
A great handling car doesn´t understeer but oversteers just enough without making the car drift (or maybe skid is what you call it.)
So you want to be on that edge were the car is about to oversteer so much that it almost go into a drift but without actually doing so. By having the caster set as I said it can help you to countersteer if the car is about to or has started drifting just a little so much. If you for instace have to much caster in that situation it could make the wheel feel like it´s jiggeling back and forth a bit.
If you have snapoversteer it might be the differential that´s is set to weak and need more preload or whatever you can adjust on it. If not that, it might be that the car is rolling to much and you need harder front- AND rear antirollbars, maybe just rear might to it.
And the last part you wrote about caster basicly, yes. I meant If you turn the frontwheels say 10 degrees in a corner, how is caster going to affect that?
// Mattias
