Engine power has never been Mercedes' problem.SiLo wrote: ↑08 Jun 2021, 00:01I wonder if the car responds more to the lower downforce package with the softer tyres because it puts more surface energy through them as there is more sliding.
Interesting to see the rear wing Hamilton ran was still quite large, yet their top speed was very impressive.
https://www.racefans.net/wp-content/upl ... 9-58-6.jpg
"We have spent our tokens, but we won't reveal how we used them just yet. That'll become clear in good time."
Nice! The v-shaped structure at the rear looks very interesting (or rather the parts immediately adjacent to it at either side). It looks as though they are using the floor as a support structure for the gearbox, rather than relying on just the tub attachment points. Given the length of the engine/bellhousing/gearbox on the Merc it is not surprising to see them doing this, but how common is it across the whole grid? It would give a large increase in installation stiffness for very little weight penalty (and that weight would be exactly where it was needed!).lio007 wrote: ↑11 Jun 2021, 17:32Nice Baku-shot from the W12's floor:
https://pbs.twimg.com/media/E3mqI_SXIAc ... me=900x900
via @NicolasF1i
Wouldn't this load the outer tips of the diffuser relative to the center, causing a slight bowing at the edges?Stu wrote: ↑12 Jun 2021, 08:08Nice! The v-shaped structure at the rear looks very interesting (or rather the parts immediately adjacent to it at either side). It looks as though they are using the floor as a support structure for the gearbox, rather than relying on just the tub attachment points. Given the length of the engine/bellhousing/gearbox on the Merc it is not surprising to see them doing this, but how common is it across the whole grid? It would give a large increase in installation stiffness for very little weight penalty (and that weight would be exactly where it was needed!).lio007 wrote: ↑11 Jun 2021, 17:32Nice Baku-shot from the W12's floor:
via @NicolasF1i
Shhh !! The floors are load tested, so as long as it passes the test…..godlameroso wrote: ↑13 Jun 2021, 23:15Wouldn't this load the outer tips of the diffuser relative to the center, causing a slight bowing at the edges?Stu wrote: ↑12 Jun 2021, 08:08Nice! The v-shaped structure at the rear looks very interesting (or rather the parts immediately adjacent to it at either side). It looks as though they are using the floor as a support structure for the gearbox, rather than relying on just the tub attachment points. Given the length of the engine/bellhousing/gearbox on the Merc it is not surprising to see them doing this, but how common is it across the whole grid? It would give a large increase in installation stiffness for very little weight penalty (and that weight would be exactly where it was needed!).lio007 wrote: ↑11 Jun 2021, 17:32Nice Baku-shot from the W12's floor:
via @NicolasF1i
Unlikely to use the floor to support the gearbox. They actually hang the floor from the gearbox using wires in tension to support it.Stu wrote: ↑12 Jun 2021, 08:08Nice! The v-shaped structure at the rear looks very interesting (or rather the parts immediately adjacent to it at either side). It looks as though they are using the floor as a support structure for the gearbox, rather than relying on just the tub attachment points. Given the length of the engine/bellhousing/gearbox on the Merc it is not surprising to see them doing this, but how common is it across the whole grid? It would give a large increase in installation stiffness for very little weight penalty (and that weight would be exactly where it was needed!).lio007 wrote: ↑11 Jun 2021, 17:32Nice Baku-shot from the W12's floor:
via @NicolasF1i
Could be, although the v-section appears to be structural?Just_a_fan wrote: ↑14 Jun 2021, 09:22Unlikely to use the floor to support the gearbox. They actually hang the floor from the gearbox using wires in tension to support it.Stu wrote: ↑12 Jun 2021, 08:08Nice! The v-shaped structure at the rear looks very interesting (or rather the parts immediately adjacent to it at either side). It looks as though they are using the floor as a support structure for the gearbox, rather than relying on just the tub attachment points. Given the length of the engine/bellhousing/gearbox on the Merc it is not surprising to see them doing this, but how common is it across the whole grid? It would give a large increase in installation stiffness for very little weight penalty (and that weight would be exactly where it was needed!).lio007 wrote: ↑11 Jun 2021, 17:32Nice Baku-shot from the W12's floor:
via @NicolasF1i
I think it's just bodywork that lives with the floor. There is this section of bodywork below and the engine cover above. No point taking it off when dropping the floor so it stays on. Much like the bargeboards.Stu wrote: ↑14 Jun 2021, 09:39Could be, although the v-section appears to be structural?Just_a_fan wrote: ↑14 Jun 2021, 09:22Unlikely to use the floor to support the gearbox. They actually hang the floor from the gearbox using wires in tension to support it.Stu wrote: ↑12 Jun 2021, 08:08
Floor/diffuser creates low pressure which "sucks"(not really) floor to the ground, floor pulls down the gearbox, and gearbox pushes tires to the ground through wishbones.Stu wrote: ↑14 Jun 2021, 09:39Could be, although the v-section appears to be structural?Just_a_fan wrote: ↑14 Jun 2021, 09:22Unlikely to use the floor to support the gearbox. They actually hang the floor from the gearbox using wires in tension to support it.Stu wrote: ↑12 Jun 2021, 08:08
