this is really interesting.. anyone with a bit of expertise able to shine some light on this?_cerber1 wrote: ↑17 Jun 2021, 15:07From @racingtech5
McLaren MCL35M Rear Wing Endplate
Revised lower part of endplate with upwashing elements. New concept that no other team has used before - over many years, the trend has been to have outwashing elements like McLaren had with its old design.
https://pbs.twimg.com/media/E4FhW5FXEAA ... =4096x4096
MrGapes wrote: ↑17 Jun 2021, 15:21this is really interesting.. anyone with a bit of expertise able to shine some light on this?_cerber1 wrote: ↑17 Jun 2021, 15:07From @racingtech5
The diffuser expansion creates upwash/outwash and this new endplate design aims to make the most of this by introducing multiple elements that will produce some local load.MrGapes wrote: ↑17 Jun 2021, 15:21this is really interesting.. anyone with a bit of expertise able to shine some light on this?_cerber1 wrote: ↑17 Jun 2021, 15:07From @racingtech5
That sounds very clever but I didn't understand any of it.aerofoilf1 wrote: ↑17 Jun 2021, 15:41The diffuser expansion creates upwash/outwash and this new endplate design aims to make the most of this by introducing multiple elements that will produce some local load.MrGapes wrote: ↑17 Jun 2021, 15:21this is really interesting.. anyone with a bit of expertise able to shine some light on this?_cerber1 wrote: ↑17 Jun 2021, 15:07From @racingtech5
Divergent flow. The flaps restrict the high pressure flow from merging with the low pressure upwash of the diffuser. Remember the rotation of the vortices under the floor. The direction of the air flow and rotation in that region is TOWARDS the center of the car, not away. The diffuser flow is from the center and diverges outward in two spirals. It is moving up and out from the center, and down and in from the periphery. Imagine flexing like Hulk Hogan(by flexing like Hulk Hogan) and you'll get a feel for how the air moves out of the diffuser when looking at the rear of the car.aerofoilf1 wrote: ↑17 Jun 2021, 15:41The diffuser expansion creates upwash/outwash and this new endplate design aims to make the most of this by introducing multiple elements that will produce some local load.MrGapes wrote: ↑17 Jun 2021, 15:21this is really interesting.. anyone with a bit of expertise able to shine some light on this?_cerber1 wrote: ↑17 Jun 2021, 15:07From @racingtech5
It looks like doing some extra up-wash paralel to traveling direction.godlameroso wrote: ↑17 Jun 2021, 16:14Divergent flow. The flaps restrict the high pressure flow from merging with the low pressure upwash of the diffuser. Remember the rotation of the vortices under the floor. The direction of the air flow and rotation in that region is TOWARDS the center of the car, not away. The diffuser flow is from the center and diverges outward in two spirals. It is moving up and out from the center, and down and in from the periphery. Imagine flexing like Hulk Hogan(by flexing like Hulk Hogan) and you'll get a feel for how the air moves out of the diffuser when looking at the rear of the car.aerofoilf1 wrote: ↑17 Jun 2021, 15:41The diffuser expansion creates upwash/outwash and this new endplate design aims to make the most of this by introducing multiple elements that will produce some local load.
Learn more here.
https://files.catbox.moe/o0uosn.jpg
Here we see exactly the same rotation of the diffuser airflow on the right side of the car when seen from the rear, but explained in a macro model.
I think you're on the right path. When air is spinning in a vortex, the process is high pressure air swirling to fill the low pressure center. Once the high pressure air fills the low pressure center, the vortex dissipates, but if you delay the high pressure air from filling the low pressure, then the vortex is maintained.BassVirolla wrote: ↑17 Jun 2021, 18:36It looks like doing some extra up-wash paralel to traveling direction.godlameroso wrote: ↑17 Jun 2021, 16:14Divergent flow. The flaps restrict the high pressure flow from merging with the low pressure upwash of the diffuser. Remember the rotation of the vortices under the floor. The direction of the air flow and rotation in that region is TOWARDS the center of the car, not away. The diffuser flow is from the center and diverges outward in two spirals. It is moving up and out from the center, and down and in from the periphery. Imagine flexing like Hulk Hogan(by flexing like Hulk Hogan) and you'll get a feel for how the air moves out of the diffuser when looking at the rear of the car.aerofoilf1 wrote: ↑17 Jun 2021, 15:41
Learn more here.
Also, I think these longitudinal slots are creating, by getting some ascending air stream from the top of the diffuser, a vortex rotating in the opposite sense of the vortex originated at the sides of the floor / diffuser, helping to seal the top of the diffuser from the air spill from behind the rear wheels and the floor / diffuser edge.
