Stiffer and more durable. So lower pressures and more abusable.
Sounds like a RBR wet dream...
I hope they don't ruin this season by putting them out of reach...
https://www.planetf1.com/news/pirelli-new-2021-tyre/
I expected as much, but was looking on speculation on who it may help most.PhillipM wrote: ↑23 Jun 2021, 23:36Historically, higher tyre pressures has always hurt Mercs race pace more than most - I think that's a bit of why they couldn't go as long as they thought last weekend with Pirelli bringing pressures up a bit - so stronger carcasses with lower pressures may help reset the status quo again.
Yes, let's give Mercedes more in-season changed advantages. After nerfing pit stops and rear wingsZynerji wrote: ↑24 Jun 2021, 14:52I expected as much, but was looking on speculation on who it may help most.PhillipM wrote: ↑23 Jun 2021, 23:36Historically, higher tyre pressures has always hurt Mercs race pace more than most - I think that's a bit of why they couldn't go as long as they thought last weekend with Pirelli bringing pressures up a bit - so stronger carcasses with lower pressures may help reset the status quo again.
Handing Merc a .02s swing against RBR might just put us at hair-splitting Q3 sessions...
This is exactly correct. The tires make up a major part of suspension compliance; stiffening the sidewall will increase the effective spring rate with who knows what effect on the teams. Going to the low profile tires for the 18" wheels next year will require a major re-think of suspension design, as the reduced sidewall compared to the 13" wheels is a huge change. It could be interesting.A stiffer carcass is going to be a crap shoot in terms of who it effects and doesn't.
Who was it that had tyre failures? Seems to me that this change helps Red Bull as they run their tyres "interestingly".Pyrone89 wrote: ↑24 Jun 2021, 20:39Yes, let's give Mercedes more in-season changed advantages. After nerfing pit stops and rear wingsZynerji wrote: ↑24 Jun 2021, 14:52I expected as much, but was looking on speculation on who it may help most.PhillipM wrote: ↑23 Jun 2021, 23:36Historically, higher tyre pressures has always hurt Mercs race pace more than most - I think that's a bit of why they couldn't go as long as they thought last weekend with Pirelli bringing pressures up a bit - so stronger carcasses with lower pressures may help reset the status quo again.
So a team with a less compliant set up, perhaps because they run low rake, might be affected more than a team with a rear end that has spare movement thanks to its arse-in-the-air approach?Rodak wrote: ↑25 Jun 2021, 01:34This is exactly correct. The tires make up a major part of suspension compliance; stiffening the sidewall will increase the effective spring rate with who knows what effect on the teams. Going to the low profile tires for the 18" wheels next year will require a major re-think of suspension design, as the reduced sidewall compared to the 13" wheels is a huge change. It could be interesting.A stiffer carcass is going to be a crap shoot in terms of who it effects and doesn't.
Mercedes at Silverstone?Just_a_fan wrote: ↑25 Jun 2021, 08:37Who was it that had tyre failures? Seems to me that this change helps Red Bull as they run their tyres "interestingly".
Mercedes at Silverstone? That was a year ago. The tyre failures in Baku will have been driving changes because the result of those failures was cars in the wall. That's a big scary "safety issue" for the powers that be.Pyrone89 wrote: ↑25 Jun 2021, 12:58Mercedes at Silverstone?Just_a_fan wrote: ↑25 Jun 2021, 08:37Who was it that had tyre failures? Seems to me that this change helps Red Bull as they run their tyres "interestingly".
Trust me, this will basically hand the championship to one of the teams, in a year where suspension changes are limited by tokens so no way to react.
Like to see your response if it turns out it accidentally gifts a huge advantage to Red Bull
I agreeJust_a_fan wrote: ↑25 Jun 2021, 13:05I must say, however, that I don't think the FIA / Pirelli are doing things to help one team or another. That's just fan-logic wanting to find conspiracies where none really exists.
Maybe, maybe not. It’s really hard to predict these things as we’re missing all the little nuanced stuff and these cars are on a razor’s edge in terms of their performance window as is.Just_a_fan wrote: ↑25 Jun 2021, 08:39So a team with a less compliant set up, perhaps because they run low rake, might be affected more than a team with a rear end that has spare movement thanks to its arse-in-the-air approach?Rodak wrote: ↑25 Jun 2021, 01:34This is exactly correct. The tires make up a major part of suspension compliance; stiffening the sidewall will increase the effective spring rate with who knows what effect on the teams. Going to the low profile tires for the 18" wheels next year will require a major re-think of suspension design, as the reduced sidewall compared to the 13" wheels is a huge change. It could be interesting.A stiffer carcass is going to be a crap shoot in terms of who it effects and doesn't.
