But you're always going to have it.. and springing the car solid is gonna do more harm than good. There's ways of making sprung mass roll work for you.Jersey Tom wrote:kilcoo316 wrote:From an aerodynamics perspective, it is... undesirable.Jersey Tom wrote:1) There's nothing inherently wrong with body roll
TrueMcMacca wrote:Excess Body Roll = Big Deal.
Not trueMcMacca wrote:The bid deal is this, if the body roll is more than intended the inside rear tyre gets unloaded and will spin up when the power is applied. So this gives two problems, 1. tyre wear and 2. time spent off throttle.
If you reduce the body roll you can get on the power earlier.
Or the tyre pressures. I'm sure it's just a case of them wanting to run as low as possible to maximise the effectiveness of the diffuser and front wing.modbaraban wrote:Today Hamilton complained about the car bottoming out a lot. It's not like they suddenly have tremendous amounts of downforce? Then it's suspension.
Your struggling with the car bottoming out?Q: You were very quick on the straight as well, fastest by about two or three kpm. Does that suggest you are not running a lot of downforce?
LH: No, it just means we have got a good Mercedes Benz engine.
So it seems that this 'SLOW' McLaren is runnig fat with fuel and is the quickest thing in a straight line?Q: Lewis, we heard you say that the car was bottoming all the time and was really very difficult to drive.
LH: Yeah, it is a very bumpy track, so I think at the time we were just a bit too low. That’s what happens when you are on heavier fuel, so we will make some changes to make sure that doesn’t happen anymore.
Bit it does reduce lap times.....ISLAMATRON wrote:fuel level (weight) doesnt have much to do with top speed, provided the straight is long enuff.
Exactly. In the grand scheme of things, reducing body roll (by itself) is EASY. Thus my original comment that whatever roll is there, is there for a reason.Tim.Wright wrote:Back on topic - roll rates are a pretty fundamental thing. doubt Mclaren would have stuffed them up.
It is quite possible. If that is symptomatic of a problem with the car rather than a setup / settings issue (remember they've changed so much on the car now that they probably don't know that much about dialing it in to a circuit) then it could take them a while to resolve.ISLAMATRON wrote:Seems to me that they are having massive problems bringing the tires up to temp(& pressure). That may be why they are bottoming so bad.
Kovi did better in FP1 than in 2, again maybe a temp thing as track temps were going down later in the day.
Actually, that is something that I always wondered about. Especially with some roll the downforce on the front wing will point towards the turn direction, and thus assist the turn. The contribution of rear wing on the overall downforce is much smaller, and the downforce from the airflow under the car should not change direction (thus remain vertical) with the roll.kilcoo316 wrote:
