Do variables such as vertical load, tyre pressure, etc effect the slip angle of a tyre?
What changes the slip angle? How is a slip angle changed?
Regards,
Of course, slip varies with camber, also. Like this:So, they found other ways to equalize the slip angles on the Fiero, namely putting most of the roll stiffness in the front suspension to force it to carry roll loads and generate higher slip angles when the car was pushed in corners to make sure the tail didn’t get away. The early Corvair has tremendous rear roll stiffness and swing axles don’t let you reduce it much, even with softer springs and considerably increased front roll stiffness, so tire pressures were pretty nearly the only tool that would really make a difference on earlies - the lates have very weak rear roll stiffness and this is mostly why they are inherently better handling cars. Most efforts to tame the Corvair are focused on increasing front roll stiffness to transfer cornering loads onto the front wheels to minimize the possibility the rear will generate larger slip angles than the front.
This sounds weird. Could you define larger?Ciro Pabón wrote:Larger tyres or bigger pressure increase slip angle.
Do you think that if the flat track you mention is covered in grease it would be the same?Jersey Tom wrote:Yes and no.
In a pure sense if you had the tire on a flat track and just held the wheel 3 degrees relative to the belt travel, it would be at 3 degrees slip angle regardless of what you did with load, inflation, etc.
Yup. No different.Belatti wrote:Do you think that if the flat track you mention is covered in grease it would be the same?Jersey Tom wrote:Yes and no.
Here is another good "wikidefinition"RacingManiac wrote:Jersey Tom is answering the question in the most basic way for the question that was asked.
"slip angle" is just the direction difference between the path the tire is going(the moving belt travel on a tire tester, or the direction the car is moving), and the direction the tire is pointing as long as there is a determined amount of adherence to make that diference possiblethe slip angle results in a force that is perpendicular to the wheel direction of travel
A non-zero slip angle arises because of deformation in the tire carcass and tread. As the tire rotates, the friction between the contact patch and the road result in individual tread 'elements' (infinitely small sections of tread) remaining stationary with respect to the road. If a side-slip velocity u is introduced, the contact patch will be deformed. As a tread element enters the contact patch the friction between road and tire means that the tread element remains stationary, yet the tire continues to move laterally. This means that the tread element will be ‘deflected’ sideways. In reality it is the tire/wheel that is being deflected away from the stationary tread element, but convention is for the co-ordinate system to be fixed around the wheel mid-plane.
As the tread element moves through the contact patch it will be deflected further from the wheel mid-plane:
Not quite. Slip angle doesn't care if the tire is adhered or sliding or somewhere in between. If there tire is sliding the slip angle doesn't go to 0.Belatti wrote:When the slip angle appears on the tire, ironically the tire is not slipping. If the surface is greasy and the vertical load is not enough in that Calspan machine, the tire will slip, so the slip angle will be...... 0
Ok sorry, you are right, it doesnt follow any relationship I know but it wont be 0 either.Jersey Tom wrote:Not quite. Slip angle doesn't care if the tire is adhered or sliding or somewhere in between. If there tire is sliding the slip angle doesn't go to 0.Belatti wrote:When the slip angle appears on the tire, ironically the tire is not slipping. If the surface is greasy and the vertical load is not enough in that Calspan machine, the tire will slip, so the slip angle will be...... 0
