Jolle wrote: ↑28 Aug 2021, 12:05
politburo wrote: ↑28 Aug 2021, 11:45
Jolle wrote: ↑28 Aug 2021, 08:48
I wasn’t (or aren’t) acting upon emotion, I’ve been saying it for years. Eau Rouge is one of the most deadly corners on the current calendar and has serious issues that can’t be fixed with extra runoff or something like that (because of the situation right around the corner) and other measures to make the combination safer have been looked at extensively by many experts over the years and in particular after Huberts crash. The “ignition” of both accidents was quite similar, the W series crash was lucky in that sense that the pileup happened earlier then at the F2 race in 2019.
This corner combination is just waiting to take someone’s life again.
Let's just agree to disagree then. The issue with the barrier is inarguable, and the only solution cannot be to alter the actual corner when there is a clear issue with barrier proximity, they already extended the runoff and tyre barrier on the inside of the Raidillon section after Hubert's car had crashed in 2019 now it is time to extend the runoff and the outside barrier for the Raidillon section.
The corner itself or it's geometry cannot be solely the issue, and I mean that with all due respect to the drivers who had their lives affected by the corner but plenty of vehicles have done 10s of thousands of laps flat out at that corner even in wet conditions including today in the F3 race going side by side, all this in the past month alone - and there have 2 big incidents at that corner due to barrier proximity, which is an issue not unique to eau rouge at this same track. Imagine a car smashing into the barrier at no name corner and spinning back on track with others following closely behind - it'd be nightmarish, there is so little runoff and room for error.
The eau rouge section has the same problem Tamburello had, nature is in the way of having sufficient run offs at the right places. Tamburello almost claimed the lives of Piquet and Berger only to be changed after Senna’s death.
Eau Rouge is more history then actual excitement at the moment, F1 cars are flat anyway there. But the chance is quite high that the next motorsport death will be at that corner.
There is actually plenty of space, so much so they allow fans to watch the race from there, simply take that space and increase the runoff, perhaps increase surface abrasion of the tarmac as well. These are real engineering solution rather than some patchwork of adding a chicane. Tamburello itself may not have been the entire problem, other corners at imola took lives as well because the cars back then had limited safety features and tore apart under load very easily - just watch the Ratzenberger crash, his car tore in half and his head snapped back due to the impact, look at the strength of the monococque today, and the halo + HANS device it is not even comparable. Also you not watch any other series than F1?. Even though the last open-wheel death was at eau rouge-raidillon, Spa had not had a driver die in a race there since the 70s atleast even with all it's configurations and many open-wheel deaths happen in American oval racing again due to barrier proximity. We have seen many recent bad accidents at Silverstone, Monza, Imola, Mugello with no casualties and perhaps that is just fortunate.
