Toro Rosso STR8 Ferrari
Re: Toro Rosso STR8 Ferrari
wesley123 wrote:it was iic
last years STR7:
I´d think the concept was already to bleed off the excessive pressure at the entrance of the sidepod back then (you can see lthrough the gap)but they have taken the concept further ...
STR8:
shelly
shelly
136
The detail I find strange is the very thick trailing edge of the pod wing - will it be a gurney or is it full thickness' last year's was much thinner
twitter: @armchair_aero
amouzouris
105
shelly wrote:The detail I find strange is the very thick trailing edge of the pod wing - will it be a gurney or is it full thickness' last year's was much thinner
Indeed! I would like to see a front view as well
miguelalvesreis
miguelalvesreis
if you enlarge the image near the "19" it seeams that it forms a kind of a gurney flap.
any chance a part not yet attached?
via formula1.com
flyboy2160
flyboy2160
84
Modern aircraft control surface design utilizes a flat, square, trailing edge instead of a sharp point trailing edge to prevent the flow at the trailing edge from wandering around over the sharp point from one surface to another. I don't know if this is the same thing.
aral
aral
26
I think that it was in the 50's when the Kamm tail became popular. From recollection the theory of a squared cut off came from the Hurricane fighter of WW2, also a Kamm design? I may be wrong, as memory fades
Crucial_Xtreme
Crucial_Xtreme
404
Gary Anderson Analysis of STR exhaust update in Barcelona
via AutoSport
RB7ate9
RB7ate9
With many teams utilizing downwash over the sidepods to aid the coanda effect from the exhausts, could the thickness of the wing over the sidepods - if it is a gurney flap - aid in drawing air out from the sidepod inlet to over the sidepod to with the low pressure area to bring in more air mass to the downwash? Making the coanda-ramp more effective?
shelly
shelly
136
What are the "aero profiled ducts" Gary Anderson is referring too in the pic crucial posted? I do not think they can be the winglets of the rear brakes' drums
RB7ate9
RB7ate9
shelly wrote:What are the "aero profiled ducts" Gary Anderson is referring too in the pic crucial posted? I do not think they can be the winglets of the rear brakes' drums
I guess he doesn't mean the brake ducts, but the channels created by the small strakes that guide the exhaust into the gap between the tire and the floor to seal the diffuser. Not quite a duct, but that's what I gathered.
Pierce89
Oh he is referring to the brake duct winglets, he's stated it many times before. As we have both mentioned before, you have to know when to ignore GA.
raymondu999
Yes. He still thinks the exhausts are blowing the rear brake duct winglets rather than the edge of the diffuser.
失败者找理由,成功者找方法
flyboy2160
flyboy2160
84
nope, current preferred design is a square edge with height ~0.5% of chord.
Monaco 2013 - Wednesday (22.05.2013)
via AMuS
