Toro Rosso STR8 Ferrari
Richard
Richard
Thread will be unlocked when the car is launched ... Monday 4th February @ 1700 GMT
http://www.tororosso.com
VoiTube Channel http://www.youtube.com/channel/HCXqwkHvQ1nrU
(Thanks to Gridlock for links)
Pre-launch speculation thread :arrow: http://www.f1technical.net/forum/viewto ... 12&t=14447
bucker
bucker
Re: Toro Rosso STR8 Ferrari
balalev
balalev
25
Owen.C93
Owen.C93
177
Matt89
Matt89
The modesty panel fitting is something appaling...
Reason: Removed quoted post right above
"Mi chiedete quale è la differenza tra la F1 eroica e quella attuale. Beh, è come se prima si camminasse in equilibrio su un filo sospeso a strapiombo sul Grand Canyon. Ora quel filo è ben teso in camera da letto, a un palmo dal materasso: l'abilità richiesta per camminarci sopra è la stessa, ma la sfida è cambiata per sempre".
- Stirling Moss -
"Se gommo tiene, io vince gara! Se gommo non tiene, io come bomba dentro montagna."
- Markku Alen -
astracrazy
astracrazy
31
looks like the STR7 but with different nose and traditional sidepods
Huntresa
Huntresa
Yeah no more MASSSIVE undercut sidepods but still undercut quite alot, but srsly they rly need to fukkn get a new Fw this year!
FrukostScones
162
you can see the lines of the modesty panel nicely...
techF1LES
176
Scoopless front brake ducts:
via Racecar Engineering http://www.racecar-engineering.com/news ... kes-debut/
Nando
Nando
Either there is some technology being shared between the two RB teams or STR simply carbon copied the front wing philosophy RBR uses.
But which directs airflow to a completely different body.
Huntresa
Huntresa
Nando wrote:Either there is some technology being shared between the two RB teams or STR simply carbon copied the front wing philosophy RBR uses.
This is the same FW from the last 2 seasons, nothing like RB that updates every other race almost :P
Nando
Nando
It´s undoubtedly a very similar wing,
Huntresa
Huntresa
Nando wrote:It´s undoubtedly a very similar wing,
The wing on this launch is 90% the exact same as last years launch wing, the change is what came during 2012 season.
And endplates stem from STR6
A very interesting big 'r' shaped vane on the floor near the tire
+ enclosed drive shaft
Predator
Any rear shots? On first glance - different sidepods, modesty panel, front brake ducts, camera pods mounted between FW pylons + they've gone for gold/bronze wheels this time.
